gazara74
Hello everyone,
Im gonna try to explain the situation as understandable as i can (my english isnt so good)
So I have 2 separate scenes for games capture and display capture (if i want to show something to the viewers)
My display capture was making problems earlier..when i use the game capture screen it is working fine,and when i switch to display capture scene it is showing black screen..i had to turn off the monitor and turn it on again in order to work...but now it does not matter if i turn on/off the monitor..it is just black screen..
If i open OBS and switch to display capture without entering the game it is working..but if i open a game to play it stops..
I was looking for this problems but it is happening on laptops because the intel gpu and nvidia gpu but i am on desktop pc..
Specs
CPU:Intel core i5-6600k
GPU:GTX 1050TI
MB: MSI z170m Mortar
ram:Crucial 16gb ddr4 2300
Primary monitor: Samsung 24" CFG70 running on 120Hz
Second monitor: LG flatron W1943SB
Also if i right click on display capture/properties it says: Display 0:1920x1080 @ 0,0
If i take a look at the second monitor it says: Display 1: 1360x768 @ 1920,305
When does the numbers after the "@" means?
All of my drivers are up to date
Do you think that the problem is with the monitor ? Cause if i switch to capture my second monitor it works all the time without any problems?!
Thanks everyone for the help!
Specs
GPU:GTX 1050TI
