DISCORD OBS WINDOW CAPTURE ISSUE (WHEN USING TABLETOP SIMULATOR)
GM TicToz
Hi OBS World
I'm a noobie here so please forgive me if this issue has been covered before - I have had a look but I don't think so.
**ISSUE: **when using OBS and Window Capturing the chat of a Discord channel and then swapping between scenes often the Discord Window Capture doesn't refresh and show on screen again in OBS.
While re-clicking Discord again fixes the issue and the Discord Window Capture reappears in OBS obviously this isn't good (ie I want the Discord Window Capture to appear all the time in OBS/my recordings without having to refresh Discord).
This seems to be particularly an issue when using Tabletop Simulator (my chosen VTT) and sharing TTS via Discord to my players.
Running a 3 year reasonably high Spec Windows 10 PC (Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz, 3192 Mhz), 32 GB RAM, up to date OBS/Discord/TTS etc)
Any ideas please on a fix please?
Thank you :)
Ps - I have also posted this message in Discord - hope a double up is allowed? Apologies if not
Hi OBS World
Thank you :)
NOW SOLVED
As per attached now solved (simple solution via the Discord forum) - see attached.
Hope this helps someone else.
