Steakpuncher
Hi All,
I'm getting sporadic disconnect issues when streaming to twitch. Sometimes it fine for weeks, other timers it happens several times a night. I believe the important part in the attached log file is:
21:38:16.209: socket_thread_windows: Received FD_CLOSE, 18864 ms since last send (buffer: 785253 / 788480)
If I manually disconnect and reconnect the stream comes back up again, but often without any sound at all (never picks back up).
If I disconnect manually and reconnect a second time, everything is fine is again.
I'm currently working my way through the issue, but I'm wondering it the additional sound issues, or if anything in the log can help narrow it down at all? I've found plenty of people with similar issues, but none with the sound issue after reconnecting.
Any help and advice would be much appreciated!
