Syrathos
Hi Everyone,
Whilst I have no reason to suspect it is OBS I am unable to replicate the issue when OBS is closed. I have the WoW Shadowlands Blue Yeti X mic which comes with sound samples. With the Logitech G hub app I can assign sound samples to the G keys on my keyboard. Then when I press the G keys the sound samples play through my speakers.
If I press the G keys when OBS is not open they play and everything is fine and dandy. If I press the G keys when I have OBS running they play, but as soon as the sound has finished my sound devices no longer function (microphone doesn't work, speakers don't work). The audio mixer in OBS no longer registers any sound and the Sound setting under Windows Settings will go from being clickable to not being clickable (grayed out).
I have to restart my computer for everything to return to normal.
Before
After (slight color difference and won't allow to be clicked.
Log Link
I have tried re-installing OBS, running just OBS without StreamElements, with StreamElements. Running in Administrator mode.
Thanks
Before
Log Link
Thanks
