Dart Connect problem seeing Virtual cam in OBS
Wayne Darter
Hello I created a virtual camera in OBS to take the image of my dart board from my web cam to play on line Darts on a website called Darts Connect. I split the dartboard image from my webCam into 2 images 1 showing the whole dartboard, and 2 a zoomed in view of the 20 wege of the board. But the on line dart program DartConnect cant seem to recognise the Virtual camera in OBS. If I have OBS open I can not see my webcam or the image from OBSVC in the dart software when testing and selecting a camera. It gives me an error saying " To use VideoConnect you must allow the webpage to access your video device." I don't know how to allow the webpage to access my Virtual camera on OBS. I have the virtual camera add on installed and started. I don't know what more I need to do. If I have the OBS turned off when I start Dart connect and test & select a camera my webcam shows up and I can see my dartboard and it will work in the DC programm, but If I select the OBS V camera from the list it shows a blue OBS screen. Then If I turn on The OBS program and start the Virtual cam I can see the split screen like I wanted but when I acknowledge that I can see my camera it goes black and does not work. and if I go back to try and select a camera again it gives me that same error message and neither camera will work. Another guy uses OBS on This Dart Connect platform so I know it will work.
I figured out the problem and it was in my chrome security settings to do with allowing camera use I had to set up the OBS Virtual camera and give it permission to let it be used by software. Fixed it. FYI in case anyone else is having this issue.
I think i have tried everything and i am still having this problem. Please help
