Question / Help CRASHING Problem please help! Crashing every 30 minutes.
x264 crashes usually indicate hardware issues such as an unstable overclock or bad memory. Check your motherboard BIOS is up to date as Ryzen CPUs sometimes have buggy microcode.
My CPU is overclocked to 4.4ghz (max turbo boost) for my cpu. Additionally I ran a memory diagnostic test and it came back negative. My motherboard has the latest bios version. Any other ideas what it could be? (all these parts are brand new and bought within the last month)
Full Specs:
Ryzen 7 3700x
G.Skill Trident Neo 32gb 3600mhz Ram
RTX 2060
ASUS Tuf X-570 Motherboard
Silicon Power m.2 1TB
Try and turn off the overclock then.
Shouldn’t I be able to overclock while streaming though? A ton of other streamers do without problems. Just not sure why this would affect my specific cpu. I believe you but is there anything else that could be affecting it?
Overclocking is by no means guaranteed, if you got really unlucky then your chip will run no faster than its rated speed.
