Question / Help Constant Audio Popping/Buffering Issues with OBS
Meatballsub
Hello,
Here is my log: https://obsproject.com/logs/ZTzl9ooHCGkpTqUx
I have been trying to figure this problem out for a couple weeks now. I am using a HD60 Pro to stream/record Nintendo Switch footage through OBS, but have constant audio buffering/popping issues even when OBS is just idling. It seems to only occur when the HD60 Pro is set to 1080P 60FPS profile, as you can uncheck 60FPS or drop down to 720P and the issue does not occur.
However, the built-in Elgato software can be used to stream/record and the audio issue is not present - it is only in OBS. I have tried matching sampling rates, disabling all non-essential playback and recording devices, new/different drivers - nothing has helped. My system is a i7-6700K @ 4.0 Ghz running Windows 10, 32GB ram and a GTX 1070 card.
Any help would be much appreciated. Thanks.
