Question / Help Consistent Audio Breaks With Blue Yeti USB Microphone
mannyfaberino
Hello everyone,
I've been having a constant issue ever since I started streaming with the Blue Yeti USB Microphone. The quality is great, but every 5 seconds consistently the mic audio cuts out for something like a millisecond. It's incredibly short, but just noticeable enough to really bother people. Here's a short clip as an example:
https://clips.twitch.tv/TentativeAcceptableCardEagleEye
The issue only presents itself in situations where I stream or record with OBS, as I have tested with Audacity and other programs. It's a very small problem, but over time has driven me crazy, particularly as I like to edit my streams into Youtube video afterwards. I've looked a ton into this, and most existing threads seem to recommend lowering my webcam resolution, but the issue persists even when I completely remove the webcam. I even unplugged all other USB devices to make sure it wasn't a power use issue. I've also tried changing sample rate and audio bitrate, and added filters, but nothing seems to remedy the issue.
Here is my last log file:
https://gist.github.com/71b3b03628f1d6f80f629228cb27a85f
Any and all help would be much appreciated! Thank you!
