02:59:41: Open Broadcaster Software v0.522b - 32bit (´・ω・`)
02:59:41: -------------------------------
02:59:41: CPU Name: Intel(R) Core(TM) i5-2320 CPU @ 3.00GHz
02:59:41: CPU Speed: 2993MHz
02:59:41: Physical Memory: 4095MB Total, 4095MB Free
02:59:41: stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
02:59:41: monitor 1: pos={0, 0}, size={1920, 1080}
02:59:41: Windows Version: 6.1 Build 7601 S
02:59:41: Aero is Enabled
02:59:41: OBS Modules:
02:59:41: Base Address Module
02:59:41: 00DE0000 OBS.exe
02:59:41: 5AC20000 OBSApi.dll
02:59:41: 641C0000 DShowPlugin.dll
02:59:41: 73B80000 GraphicsCapture.dll
02:59:41: 72B20000 NoiseGate.dll
02:59:41: ------------------------------------------
02:59:41: Adapter 1
02:59:41: Video Adapter: NVIDIA GeForce GTX 650 Ti
02:59:41: Video Adapter Dedicated Video Memory: 1020985344
02:59:41: Video Adapter Shared System Memory: 3221221376
02:59:41: =====Stream Start: 2013-06-30, 02:59:41===============================================
02:59:41: Multithreaded optimizations: On
02:59:41: Base resolution: 1920x1080
02:59:41: Output resolution: 1280x720
02:59:41: Loading up D3D10...
02:59:41: Playback device {0.0.0.00000000}.{1e84a2a4-8c2c-4df1-aa76-9ac29a18b1b3}
02:59:41: Using desktop audio input: Headset Earphone (3- ASTRO MixAmp Pro )
02:59:41: Using auxilary audio input: Headset Microphone (3- ASTRO MixAmp Pro )
02:59:41: Audio Encoding: AAC
02:59:41: bitrate: 128
02:59:41: Using Window Capture
02:59:41: Video Encoding: x264
02:59:41: fps: 30
02:59:41: width: 1280, height: 720
02:59:41: preset: veryfast
02:59:41: CBR: yes
02:59:41: CFR: no
02:59:41: max bitrate: 1000
02:59:43: Using RTMP service: Twitch / Justin.tv
02:59:43: Server selection: rtmp://live-ord.justin.tv/app
02:59:47: Using Monitor Capture
02:59:50: SO_SNDBUF was at 8192
02:59:50: SO_SNDBUF is now 65536
02:59:54: Using Monitor Capture
02:59:57: Using Window Capture
03:01:04: RTMPPublisher::SocketLoop: Socket error, send() returned -1, GetLastError() 10054
03:01:04: Total frames rendered: 2433, number of frames that lagged: 108 (4.44%) (it's okay for some frames to lag)
03:01:04: librtmp error: WriteN, RTMP send error 10054 (79 bytes)
03:01:04: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
03:01:04: Number of times waited to send: 0, Waited for a total of 0 bytes
03:01:04: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
03:01:04: =====Stream End: 2013-06-30, 03:01:04=================================================
03:01:14: =====Stream Start: 2013-06-30, 03:01:14===============================================
03:01:14: Multithreaded optimizations: On
03:01:14: Base resolution: 1920x1080
03:01:14: Output resolution: 1280x720
03:01:14: ------------------------------------------
03:01:14: Loading up D3D10...
03:01:14: Playback device {0.0.0.00000000}.{1e84a2a4-8c2c-4df1-aa76-9ac29a18b1b3}
03:01:15: ------------------------------------------
03:01:15: Using desktop audio input: Headset Earphone (3- ASTRO MixAmp Pro )
03:01:15: Using auxilary audio input: Headset Microphone (3- ASTRO MixAmp Pro )
03:01:15: Audio Encoding: AAC
03:01:15: bitrate: 128
03:01:15: Using Window Capture
03:01:15: Video Encoding: x264
03:01:15: fps: 30
03:01:15: width: 1280, height: 720
03:01:15: preset: veryfast
03:01:15: CBR: yes
03:01:15: CFR: no
03:01:15: max bitrate: 1000
03:01:16: Using RTMP service: Twitch / Justin.tv
03:01:16: Server selection: rtmp://live-ord.justin.tv/app
03:01:17: SO_SNDBUF was at 8192
03:01:17: SO_SNDBUF is now 65536
03:01:18: Using Monitor Capture
03:02:04: RTMPPublisher::SocketLoop: Socket error, send() returned -1, GetLastError() 10054
03:02:04: Total frames rendered: 1028, number of frames that lagged: 914 (88.91%) (it's okay for some frames to lag)
03:02:04: librtmp error: WriteN, RTMP send error 10054 (79 bytes)
03:02:04: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
03:02:04: Number of times waited to send: 0, Waited for a total of 0 bytes
03:02:04: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
03:02:04: =====Stream End: 2013-06-30, 03:02:04=================================================
03:03:49:
03:03:49: Profiler results:
03:03:49:
03:03:49: ==============================================================
03:03:49: frame - [100%] [avg time: 18.266 ms] [avg calls per frame: 1] [children: 96.5%] [unaccounted: 3.5%]
03:03:49: | scene->Preprocess - [88.8%] [avg time: 16.228 ms] [avg calls per frame: 1]
03:03:49: | video encoding and uploading - [7.66%] [avg time: 1.399 ms] [avg calls per frame: 1] [children: 7.53%] [unaccounted: 0.131%]
03:03:49: | | CopyResource - [0.12%] [avg time: 0.022 ms] [avg calls per frame: 0]
03:03:49: | | conversion to 4:2:0 - [0.0219%] [avg time: 0.004 ms] [avg calls per frame: 0]
03:03:49: | | call to encoder - [7.26%] [avg time: 1.326 ms] [avg calls per frame: 0]
03:03:49: | | sending stuff out - [0.126%] [avg time: 0.023 ms] [avg calls per frame: 0]
03:03:49:
