Connect 2 camera's with same name not possible?
GerjanS
Hi,
I just bought 2 Sony ZV-1 camera's to make livestreams from 2 different angles (for meditation and yoga classes and now I have only 1 angle while I switch positions, see for example).
I can connect webcams next to 1 ZV-1 camera, but it won't find both ZV-1 Camera's.
It's only finding 1.
Maybe this is because both devices have the same name?
If so, will it be a solution to use a capture card for 1 of the ZV-1 Camera's?
So connect 1 directly with USB and the other wit a capture card?
Looking forward to your help.
Thank you!
Gerjan
dgatwood
USB is always tricky. In theory, if they consistently are attached to specific ports, they should be uniquely identifiable, but it depends a bit on whether they're actually ending up on separate USB busses. But Apple's AV frameworks have never been great at that, unfortunately, so your mileage may vary.
