Question / Help Combing Audio Interface audio with system audio (Mac)
Xand3r
Hey guys. I've scoured the internet for an answer, but alas I have not found one.
Here's the situation. First off... I'm on a 2016 Mac pro version 10.11.4
The end goal is: I want to be able to stream me producing music.
I want to be able to send the source audio from my computer and also use a mic running through my komplete audio 6 interface, while also listening through my monitor speakers that are running through my komplete audio 6 interface.
My issue is that I am unable to combine both of these together. I've gone through the Audio Midi Setup instructions with aggregation probably 15 times trying to make it work, but it won't allow me use both interface and built in audio at the same time. I can use the multi-output option, BUT that doesn't seem to be an option on OBS.
I've looked into soundflower, but with my updated operating system it won't allow me to use the software. Is there a way to do it with another piece of software or is there something more simple that I am just missing?
Any help would be greatly appreciated!
Let me know if I should clarify anything (first time posting on a forum)
Narcogen
Sound Siphon (linked above) also works well. For those unable to get SoundFlower working correctly, it is a good option-- just not necessarily worth paying $40 for *if* you can get the free SoundFlower to work.
jHoover
Hey, Xand3r, I also use an external interface. Does your interface has a loopback function?
I use a Saffire pro 14 and with the loopback routing it works. The only problem is with obs mono channels. They come either from left or right, unfortunately the force mono function makes the whole signal mono. I started a thread on this, I hope there will be some progress.
Cheers ;)
