Question / Help Color issues while using video capture device. Help!
realityaxe
I'm having trouble getting the colors, mainly green to look like they should. I'm using the latest version of OBS(0.637b) on Windows 7 64-bit system. The problem is happening when I add a video capture device, either AmaRecTV Live or my capture card (SC-512NL-1). As you can see with the pictures there is a big difference in color and I'm not sure what's causing it. I have tried messing with the settings of my capture card, but it looks fine in AmaRecTV Live so I was at a loss as to why OBS would make the colors so much brighter. I have included a picture from both OBS and AmaRecTV Live. Please let me know what I should do, or what more information you need from me to fix this problem. I would really like to have the same colors!
  • 2014-10-28-2233-42.log
Hopewithinchaos
Forum Moderator
Alright, in your NVidia control panel, at the video portion:
Adjust Video Color Settings: Have you modified this at ALL?
Adjust Video Image settings: Have you changed anything here?
if in the Image portion, it's left on "Video Player Default" on both, Try clicking "Use Nvidia Setting" On both, but leaving them both at 0.
The preview window of OBS is seen in the system as a video (Because it is) And these settings will change how you perceive that video. Most systems don't do anything but it can happen (Did it on my old rig. )
ViciousXUSMC
I think this is the same problem I am having but I am not using a capture device just the built in Monitor capture for OBS.
Green is looking very toned down, other colors not so bad as far as I can tell.
