Capture Display without Taskbar
SmashWhiskey
Hi All,
Having trouble trying to figure out a way to capture just a browser window, but also have it capture the cursor and drawing tools. It seems to only want to capture the cursor and drawing tool (I use Zoomit64 to draw arrows, boxes, underlines, etc.) when using Display Capture. Is there any way to capture the Display without the taskbar? This would solve literally every problem I have with this application. Thanks in advance!
You could apply a Crop filter to the source, or just hold ALT and drag the bottom handle to crop off the taskbar at the bottom/top/sides as needed.
Oh man, thank you so much. This is exactly what I needed. Didn't even think to hold ALT to keep the dimensions. Appreciate the solution!
