Capture card losing signal randomly
Zephrron
Hello I recently started streaming with a stream pc. Everything works amazing when it works but usually once a stream my video capture loses signal telling me to check cables. All the cables are new and in good working order. When I try to delete the video capture and re add it, obs crashes. After it closes I try to restart it and it says obs is still running. So I usually restart my pc, re-add the video capture and then it works great the rest of the day. Also while this is happening sometimes my webcam will freeze aswell. Any suggestions on how to fix this?
Game pc:
i7 5930k
Gtx 1080ti
16 gb ram
Windows 10
stream pc:
i7 9700k
Rtx 2080
16 gb ram
Windows 10
avermedia extremecap u3 capture card.
