Bug Report Cam causing sound problems
demonsliewithin
First off, great piece of software. Just wanted to give kudos to the developers for putting this together.
Though, I do have a problem! When I add my webcam to the scene it causes all of my computers sound to be very robotic. This problem is easily resolved by just removing the camera from the scene. I add the cam usually after setting up the game source capture (as a global source).
I have updated all my drivers to current so that should not be an issue. I'm also running the most current version of OBS as well. Perhaps there's just a setting somewhere that I'm missing?
(Originally posted this in the wrong spot, moved for correctness)
Lain
Forum Admin
Lain
Forum Moderator
Developer
Try switching the USB port which the webcam uses. Sometimes that can, surprisingly, cause some issues. Pretty sure it's not directly caused by OBS, though.
demonsliewithin
I thought maybe it had to do with the fact that I've got multiple different sound drivers for different interfaces. HDMI, normal 3.5mm and the cam itself has a microphone.
Though switching USB ports did seem to resolve the problem for now. I had it plugged into a USB2.0 port...moved it to another non-2.0 port.
