Question / Help C100 - BM Deck Link Duo 2 - HDMI to SDI converter Problems - PLEASE HELP
Jonshish
Hi,
Brand new here. I'm having problems getting my C100 to connect to OBS. I am running it through an hdmi output from the camera, to an hdmi to sdi converter box, that goes straight into my DeckLink Duo 2 inside of my computer. I keep getting a black display screen in OBS. I've tried to configure the resolutions and frame rate to the same settings in both OBS and the camera. Still not working.
here is my most recent log
00:08:04.954: CPU Name: AMD Ryzen Threadripper 1950X 16-Core Processor
00:08:04.954: CPU Speed: 3394MHz
00:08:04.955: Physical Cores: 16, Logical Cores: 32
00:08:04.955: Physical Memory: 65410MB Total, 60708MB Free
00:08:04.955: Windows Version: 10.0 Build 16299 (revision: 611; 64-bit)
00:08:04.955: Running as administrator: false
00:08:04.955: Aero is Enabled (Aero is always on for windows 8 and above)
00:08:04.955: Windows 10 Gaming Features:
00:08:04.955: Game Bar: Off
00:08:04.955: Game DVR: Off
00:08:04.955: Game DVR Background Recording: Off
00:08:04.956: Sec. Software Status:
00:08:04.957: Windows Defender Antivirus: enabled (AV)
00:08:04.957: Windows Firewall: enabled (FW)
00:08:04.959: Windows Defender Antivirus: enabled (ASW)
00:08:04.959: Browser Hardware Acceleration: true
00:08:04.959: Portable mode: false
00:08:05.067: OBS 22.0.1 (64-bit, windows)
00:08:05.067: ---------------------------------
00:08:05.076: ---------------------------------
00:08:05.076: audio settings reset:
00:08:05.076: samples per sec: 44100
00:08:05.076: speakers: 2
00:08:05.077: ---------------------------------
00:08:05.077: Initializing D3D11...
00:08:05.077: Available Video Adapters:
00:08:05.078: Adapter 1: NVIDIA GeForce GTX 1080 Ti
00:08:05.078: Dedicated VRAM: 3077570560
00:08:05.078: Shared VRAM: 4229326848
00:08:05.078: output 1: pos={0, 0}, size={3840, 2160}, attached=true
00:08:05.078: output 2: pos={3840, 0}, size={3840, 2160}, attached=true
00:08:05.080: Loading up D3D11 on adapter NVIDIA GeForce GTX 1080 Ti (0)
00:08:05.159: D3D11 loaded successfully, feature level used: 45056
00:08:05.794: ---------------------------------
00:08:05.794: video settings reset:
00:08:05.794: base resolution: 3840x2160
00:08:05.794: output resolution: 1280x720
00:08:05.794: downscale filter: Bicubic
00:08:05.794: fps: 30/1
00:08:05.794: format: NV12
00:08:05.794: YUV mode: 601/Partial
00:08:05.797: Audio monitoring device:
00:08:05.797: name: Default
00:08:05.797: id: default
00:08:05.797: ---------------------------------
00:08:05.798: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
00:08:05.799: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/concrt140.dll' not found, loading of module failed
00:08:05.804: [CoreAudio encoder]: Adding CoreAudio AAC encoder
00:08:05.830: [AMF] AMF Test failed due to one or more errors.
00:08:05.830: Failed to initialize module 'enc-amf.dll'
00:08:05.840: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
00:08:05.840: LoadLibrary failed for '../../obs-plugins/64bit/libEGL.dll': The specified procedure could not be found.
00:08:05.840: (127)
00:08:05.840: Module '../../obs-plugins/64bit/libEGL.dll' not loaded
00:08:05.841: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
00:08:05.841: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/msvcp140.dll' not found, loading of module failed
00:08:05.842: [obs-browser]: Version 2.1.2
00:08:05.844: NVENC supported
00:08:05.896: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/Qt5Network.dll' not found, loading of module failed
00:08:05.898: Failed to load 'en-US' text for module: 'StreamDeckPlugin.dll'
00:08:05.901: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/ucrtbase.dll' not found, loading of module failed
00:08:05.901: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/vccorlib140.dll' not found, loading of module failed
00:08:05.901: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/vcruntime140.dll' not found, loading of module failed
00:08:05.903: VLC found, VLC video source enabled
00:08:05.910: ---------------------------------
00:08:05.910: Loaded Modules:
00:08:05.910: win-wasapi.dll
00:08:05.910: win-mf.dll
00:08:05.910: win-dshow.dll
00:08:05.910: win-decklink.dll
00:08:05.910: win-capture.dll
00:08:05.910: vlc-video.dll
00:08:05.910: text-freetype2.dll
00:08:05.910: StreamDeckPlugin.dll
00:08:05.910: rtmp-services.dll
00:08:05.910: obs-x264.dll
00:08:05.910: obs-vst.dll
00:08:05.910: obs-transitions.dll
00:08:05.910: obs-text.dll
00:08:05.910: obs-qsv11.dll
00:08:05.910: obs-outputs.dll
00:08:05.910: obs-filters.dll
00:08:05.910: obs-ffmpeg.dll
00:08:05.910: obs-browser.dll
00:08:05.910: image-source.dll
00:08:05.910: frontend-tools.dll
00:08:05.910: enc-amf.dll
00:08:05.910: coreaudio-encoder.dll
00:08:05.910: ==== Startup complete ===============================================
00:08:05.917: Service '' not found
00:08:05.919: All scene data cleared
00:08:05.919: ------------------------------------------------
00:08:05.963: WASAPI: Device 'DELL P2715Q (NVIDIA High Definition Audio)' initialized
00:08:05.967: Blackmagic Device: Starting capture...
00:08:05.973: Switched to scene 'Scene'
00:08:05.973: ------------------------------------------------
00:08:05.973: Loaded scenes:
00:08:05.973: - scene 'Scene':
00:08:05.973: - source: 'Display Capture' (monitor_capture)
00:08:05.973: - source: 'Blackmagic Device' (decklink-input)
00:08:06.027: CalculateFileHash: Failed to open file 'C:\Users\Jonshish\AppData\Roaming\obs-studio\updates\whatsnew.json':
00:08:06.045: adding 69 milliseconds of audio buffering, total audio buffering is now 69 milliseconds
00:08:11.497: Blackmagic Device: Stopping capture of 'DeckLink Duo (1)'...
00:08:11.520: Blackmagic Device: Starting capture...
00:08:11.523: Blackmagic Device: Failed to enable video input
00:08:13.364: Blackmagic Device: Starting capture...
00:08:14.530: Blackmagic Device: Stopping capture of 'DeckLink Duo (2)'...
00:08:14.562: Blackmagic Device: Starting capture...
00:08:14.625: adding 23 milliseconds of audio buffering, total audio buffering is now 92 milliseconds
00:08:15.764: Blackmagic Device: Stopping capture of 'DeckLink Duo (1)'...
00:08:15.789: Blackmagic Device: Starting capture...
00:08:15.792: Blackmagic Device: Failed to enable video input
00:08:17.897: Blackmagic Device: Starting capture...
00:08:17.899: Blackmagic Device: Failed to enable video input
00:08:24.097: Blackmagic Device: Starting capture...
00:08:24.098: Blackmagic Device: Failed to enable video input
00:08:25.730: Blackmagic Device: Starting capture...
00:08:25.731: Blackmagic Device: Failed to enable video input
00:08:30.264: Blackmagic Device: Starting capture...
00:08:30.265: Blackmagic Device: Failed to enable video input
00:09:21.330: Blackmagic Device: Starting capture...
00:09:30.964: Blackmagic Device: Stopping capture of 'DeckLink Duo (2)'...
00:09:30.980: Blackmagic Device: Starting capture...
00:09:59.264: Blackmagic Device: Stopping capture of 'DeckLink Duo (2)'...
00:09:59.290: Blackmagic Device: Starting capture...
00:10:12.264: Blackmagic Device: Stopping capture of 'DeckLink Duo (2)'...
00:10:12.291: Blackmagic Device: Starting capture...
00:10:15.397: Blackmagic Device: Stopping capture of 'DeckLink Duo (2)'...
00:10:15.421: Blackmagic Device: Starting capture...
00:10:15.484: adding 23 milliseconds of audio buffering, total audio buffering is now 116 milliseconds
00:10:18.397: Blackmagic Device: Stopping capture of 'DeckLink Duo (2)'...
00:10:18.422: Blackmagic Device: Starting capture...
00:10:20.264: Blackmagic Device: Stopping capture of 'DeckLink Duo (2)'...
00:10:20.291: Blackmagic Device: Starting capture...
00:10:21.630: Blackmagic Device: Stopping capture of 'DeckLink Duo (2)'...
00:10:21.648: Blackmagic Device: Starting capture...
00:10:21.742: adding 46 milliseconds of audio buffering, total audio buffering is now 162 milliseconds
00:10:23.397: Blackmagic Device: Stopping capture of 'DeckLink Duo (2)'...
00:10:23.428: Blackmagic Device: Starting capture...
00:10:25.497: Blackmagic Device: Stopping capture of 'DeckLink Duo (2)'...
00:10:25.526: Blackmagic Device: Starting capture...
00:10:32.064: Blackmagic Device: Stopping capture of 'DeckLink Duo (2)'...
00:10:32.089: Blackmagic Device: Starting capture...
00:10:40.364: Blackmagic Device: Stopping capture of 'DeckLink Duo (2)'...
00:10:40.386: Blackmagic Device: Starting capture...
00:11:01.397: Blackmagic Device: Stopping capture of 'DeckLink Duo (2)'...
00:11:01.421: Blackmagic Device: Starting capture...
00:12:05.530: Blackmagic Device: Stopping capture of 'DeckLink Duo (2)'...
00:12:05.555: Blackmagic Device: Starting capture...
00:12:28.905: User added source 'Video Capture Device' (dshow_input) to scene 'Scene'
00:12:28.910: Video Capture Device: DecodeDeviceId failed
00:12:28.910: Video Capture Device: Video configuration failed
00:12:29.106: ---------------------------------
00:12:29.106: [DShow Device: 'Video Capture Device'] settings updated:
00:12:29.106: video device: Blackmagic WDM Capture (4)
00:12:29.106: video path: \\?\decklink#avstream#8&3afb945a&0&0#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\decklinkcapture4
00:12:29.106: resolution: 720x486
00:12:29.106: fps: 29.97 (interval: 333667)
00:12:29.106: format: UYVY
00:12:29.108: using video device audio: yes
00:12:29.108: sample rate: 48000
00:12:29.108: channels: 2
00:12:29.108: audio type: Capture
00:12:30.614: DShow: Run failed (0x80070020): The process cannot access the file because it is being used by another process.
00:12:30.614:
00:12:32.440: ---------------------------------
00:12:32.440: [DShow Device: 'Video Capture Device'] settings updated:
00:12:32.440: video device: Decklink Video Capture (2)
00:12:32.440: video path:
00:12:32.440: resolution: 720x486
00:12:32.440: fps: 29.97 (interval: 333667)
00:12:32.440: format: UYVY
00:12:32.441: DShow: HDevice::ConnectPins: failed to connect pins (0x8007001F): A device attached to the system is not functioning.
00:12:32.441:
00:12:32.610: DShow: HDevice::ConnectFilters: RenderStream failed (0x80070057): The parameter is incorrect.
00:12:32.610:
00:12:36.525: Video Capture Device: ResolutionValid failed
00:12:36.525: Video Capture Device: Video configuration failed
00:12:40.070: ---------------------------------
00:12:40.070: [DShow Device: 'Video Capture Device'] settings updated:
00:12:40.070: video device: Decklink Video Capture (2)
00:12:40.070: video path:
00:12:40.070: resolution: 1920x1080
00:12:40.070: fps: 30.00 (interval: 333333)
00:12:40.070: format: HDYC
00:12:40.071: DShow: HDevice::ConnectPins: failed to connect pins (0x8007001F): A device attached to the system is not functioning.
00:12:40.071:
00:12:40.183: DShow: HDevice::ConnectFilters: RenderStream failed (0x80070057): The parameter is incorrect.
00:12:40.183:
00:12:47.072: ---------------------------------
00:12:47.072: [DShow Device: 'Video Capture Device'] settings updated:
00:12:47.072: video device: Decklink Video Capture (2)
00:12:47.072: video path:
00:12:47.072: resolution: 1920x1080
00:12:47.072: fps: 30.00 (interval: 333333)
00:12:47.072: format: HDYC
00:12:47.072: DShow: HDevice::ConnectPins: failed to connect pins (0x8007001F): A device attached to the system is not functioning.
00:12:47.072:
00:12:47.177: DShow: HDevice::ConnectFilters: RenderStream failed (0x80070057): The parameter is incorrect.
00:12:47.177:
00:13:10.203: ---------------------------------
00:13:10.203: [DShow Device: 'Video Capture Device'] settings updated:
00:13:10.203: video device: Decklink Video Capture (2)
00:13:10.203: video path:
00:13:10.203: resolution: 1920x1080
00:13:10.203: fps: 30.00 (interval: 333333)
00:13:10.203: format: HDYC
00:13:10.203: DShow: HDevice::ConnectPins: failed to connect pins (0x8007001F): A device attached to the system is not functioning.
00:13:10.203:
00:13:10.337: DShow: HDevice::ConnectFilters: RenderStream failed (0x80070057): The parameter is incorrect.
00:13:10.337:
00:13:20.171: User Removed source 'Blackmagic Device' (decklink-input) from scene 'Scene'
00:13:20.197: Blackmagic Device: Stopping capture of 'DeckLink Duo (2)'...
00:13:23.090: User Removed source 'Video Capture Device' (dshow_input) from scene 'Scene'
00:13:33.185: User added source 'Blackmagic Device' (decklink-input) to scene 'Scene'
00:13:35.530: Blackmagic Device: Starting capture...
00:13:37.764: Blackmagic Device: Stopping capture of 'DeckLink Duo (2)'...
00:13:37.790: Blackmagic Device: Starting capture...
00:13:39.397: Blackmagic Device: Stopping capture of 'DeckLink Duo (1)'...
00:13:39.403: Blackmagic Device: Starting capture...
00:13:39.404: Blackmagic Device: Failed to enable video input
00:13:40.797: Blackmagic Device: Starting capture...
00:13:40.797: Blackmagic Device: Failed to enable video input
00:13:41.897: Blackmagic Device: Starting capture...
00:13:47.897: Blackmagic Device: Stopping capture of 'DeckLink Duo (2)'...
00:13:47.927: Blackmagic Device: Starting capture...
00:13:57.464: Blackmagic Device: Stopping capture of 'DeckLink Duo (2)'...
00:13:57.492: Blackmagic Device: Starting capture...
