Hi guys,
I'm currently trying to set up OBS on my laptop.
It's a Dell Inspiron 14Z Ultrabook, built in are an Intel HD 4000 and a AMD Mobility Radeon HD 7570M.
The weird thing is that it doesn't matter which programm I try to add to my szene, everything will produce a blackscreen unless set compability mode.
In example, I have set both OBS and all the different League of Legends executables to high power, and google chrome to power saver.
Theoretically, only Chrome should give me a blackscreen, and League of Legends should produce a picture (I use window capture for the client and game capture in-game)
However, I'm getting a blackscreens on everything.
In the "Video" tab of the OBS settings I can only select the Intel HD card, not the AMD card. Is this a driver problem?
I tried running both the 64- and 32-bit versions of OBS as Admin.
My Logfile: http://pastebin.com/df4w7x7a
If I forgot to mention anything important, please tell me and I will try to add that asap.
With best regards,
Bombolero
With best regards,
Bombolero
