Question / Help Blackmagic intensity and audio problems
JonJ
I am trying to make stream to youtube from my camera though BM intensity shuttle to my computer, the image is getting here but i can't get audio, i am streaming but he does not recognize my audio. Here's how all is setup
Camera (with audio levels, high) >>>>>>(trough HDMI)>>>>>> Blackmagic Intensity Shuttle>>>>>>>>>Trough Thunderbolt>>>>> Computer. I open Black Syphon that sees my my BM card, then i open OBS that sees Black Syphon, he sees the image i just have not found a way to toggle audio, can anybody help me ?
By the way : i apologize any mistakes in my english, its not my nativa language.
Thanks ahead, Jon
Because you are using Black Syphon, I am assuming you are on Mac OS X. I think you meant to post this in the OBS Multiplatform Support forum.
Black Syphon is strictly a video capture protocol; there is no way to capture an audio using it. The good news is that in the new version of OBS Multiplatform (since 0.9.0), we offer full support for capturing Blackmagic devices. Once you have updated to the latest version (0.9.1):
  1. Open OBS
  2. Add a new source, select "Blackmagic Device"
  3. Select your device and desired capture mode, press OK
  4. Check to make sure your configuration looks something like this:
You'll see that Blackmagic Device is listed in the audio mixer panel on the right.
Best of luck!
  1. Open OBS
Best of luck!
Does this mean you can opt out of using Black Syphon all together and use this?
