Bug Report Blackmagic Audio Input Issue.
Dig_Douglas
Hey all, forgive me if this was answered before. I looked around and didn't see anything.
When adding my Blackmagic card to OBS, video comes up fine but it does not pick up audio from the card. In the audio setting panel, there is no selection for the Blackmagic card.
Even if there was would I be able to use my Mic in, and the audio from the BM card mixed together?
Reinstalling the blackmagic drivers did not alleviate the issue.
Thanks for the help.
EDIT: oh hey would you look at that. A bit more searching and I found the reason. It seems as if there is a bug with audio on external capture devices. No big deal. I hope it gets fixed soon. Thanks guys.
Dig_Douglas
I just downloaded the beta version. IT WORKS!
Thanks for the heads up. Now if there was only a way to mute the sound coming from the capture card, so I don't hear it. and still stream it out....
Dig_Douglas
Is there some way to donate? I feel that Jim deserves some sort of thanks. Thanks in the form of money are always the best kind of thanks.
If not, thanks! :)
