Question / Help Best settings for FPS? ADVANCED help
cyanide814
Ok i stream Infestation survivor stores (War Z) and ever since their new update i can't really stream it the best anymore like i used to.
Now these are my specs
660TI
and FX - 8350 OC 4.62GHZ
now what settings should i make the ADVANCED area to make it less harder on my system but still look good.
I have my CPU preset at veryfast now.. used to be medium - still no difference
what are these newer video settings like CFR? and stuff like that should i check it?
what is encoding profile?
mulitithreaded optimizations...
basically everything in the advanced area and video i just need help to tweak..
and should i have "Disable AERO" Checked or un checked?
