Schauerland
Hey,
what would be the BEST (most lossless) color quality setting for x264 lossless using the qp=0 parameter?
if i set Color Format to RGB, mediainfo tells it's 4:2:0
if i set Color Format to I444 mediainfo tells it's 4:4:4 and the record (still image) is larger.
what would be the recommend YUV Color Range? Full or Limited?
and will Color Range and Color Space be ignored if i use RGB as Color Format?
what about parallel streaming will it automaticly converted to 4:2:0?
im asking because im using Premiere to cut the recorded stuff and premiere converts everything to rgb as far as i now
and if i record in 2560x1440 premiere won't playback the preview because it seems to be too heavy for my cpu (xeon e3)
Thanks
Thanks
