Behringer UMC 404HD - no audio in OBS
Mar100
Hi, I'm trying to capture audio from my Behringer UMC 404HD in OBS on Windows. I want to use output channels 1/2 (master output from djay) as audio source for streaming.
Important: I don't use speakers, I monitor only through headphones connected directly to the Behringer. No audio goes through Windows default output.
I tried:
  • Desktop audio capture with Behringer as default Windows device
  • obs-asio plugin
  • ATK plugin
  • VoiceMeeter Banana as bridge
Nothing works, the audio meter in OBS doesn't move.
I use djay as my DJ software — I can't load Restream or VoiceMeeter on the master channel in djay, so the workaround I found for Ableton doesn't apply here.
The Behringer works fine simultaneously in multiple apps (Ableton, djay, YouTube) so it's not in exclusive mode.
OBS version: 32.1.2 Windows 11
Any help appreciated, thank you!
