Hello everybody!
Thank you very much for coming to help, I really appreciate your time. You see, I just started to do the whole streaming thing. I'm very new into this, and even though I ain't an imbecile with computers, I still have a hard time figuring most of these things. I been trying to stream from my laptop, but before I did I wanted to record some of my gameplay. Well, I started recording and the frames were dropping like crazy! It was unplayable! I went back to the recording, and you can tell when the frame dropping happens.
I was so sure that it was my laptop's specs that were causing the stream to lag like that, but my friends reassure me that the laptop has the necessary specs to run fine. So I honestly don't know if its an issue with my laptop or the way I set the OBS (and no, I did not touch any of the Advanced Options).
- This is my log file: https://obsproject.com/logs/JGZrCr1fudg2byqh
- My laptop has the following specs:
- CPU: Intel Core i5-8300H (quad-core, 8MB cache, up to 4.0GHz w/ Turbo Boost)
Graphics: Nvidia GeForce GTX 1050 Ti (4GB GDDR5); Intel UHD Graphics 630
RAM: 8GB DDR4 (2,666MHz)
Screen: 15.6-inch FHD (1,920 x 1,080) anti-glare LED-backlit
Storage: 128GB SSD: 1TB HDD @ 5,400RPM
Ports: 1 x USB 2.0, 2 x USB 3.1 Type-A, 1 x HDMI, 1 x ethernet, 1 x SD reader
Battery: 56 Whr, 4-cell Battery (Integrated)
Connectivity: Intel Wireless 9462AC card (802.11ac + Bluetooth 5.0)
Camera: widescreen HD (720p) webcam; dual array digital mic
Weight: 5.57 pounds (2.53kg)
Size: 14.96 x 10.16 x 0.89 inches (380 x 258 x 22.7mm; W x D x H)
