Question / Help Beast PC needs help with settings
leffefeffe
Hello guys, im very bad at OBS settings. i have a beast PC i bought a few weeks ago and i want to start streaming cs and other games, but i need help to get my settings perfect! :D
setup taken from my steam profile so alot of junk in it aswell:
upload speed: 43 mbps
download speed: 95 mbps
OS: Windows 8.1 Pro
Case: Fractal Design Define R5, Titanium
Motherboard: ASUS Z170-A ATX
RAM: Corsair 16GB DDR4 2133Mhz Vengeance LPX
Power: Corsair CS 850W 80+ Gold
CPU: Intel Core i7 6700K 4.0 GHz, 8MB
GPU: Nvidia Geforce GTX 780 4Ghz Edition
CPU Watercooling: Corsair Hydro H110
HDD: 3 TB
SSD: 250 GB
Main monitor: BenQ 24" XL2430T LED 144HZ 3D
Second monitor: Asus 24" 1080p
Mouse: Zowie FK2
Keyboard: Ozone Strike Battle Mechanical Gaming Keyboard
Headphones: Qpad QH90
Speakers: Logitech Z550
Mousepad: Xtrfy Mousepad NiP Italian Large
FerretBomb
If you're a non-partner, it's still strongly advised not to exceed 2000kbps bitrate to Twitch; going above that point will cause increasing numbers of your potential viewers to constantly buffer.
720p@30fps is the best tradeoff point at 2000kbps between resolution, smoothness, and image fidelity.
480p@60fps is useful if you play retro games that use sprite blitting (flashing them quickly to simulate transparency)
480p@30fps is for those who want extra-high image fidelity and less blocking.
Past that, you can turn down your x264 preset to one step slower, then test for 20 minutes of streaming with active gaming. Keep an eye on your CPU temperature, load, and throttling. The slower the preset, the better your stream will look at a given bitrate. Slower = more CPU used = better compression = better looking stream.
