Hi,
Recently I bought a second PC and decided to try stream on 2 units. My primary rig has GTX 980 and I'm using 2 monitors through display ports. I plugged the Avermedia Live Gamer Portable 2 card through HDMI (Mr obvious) and my pc detected 3rd output (Nvidia dashboard). To have the same content as on my main display I set to display at AVT GC510 (port of the Avermedia card) the clone of my primary monitor.
On second pc I've set to detect the picture from the external card and everything works fine in terms of graphic. So far I could capture 1080p/60fps without CPU choking etc. The problem is that the OBS doesn't recognize the sound (or doesn't have it from the card).
Could you help me with this issue? I've checked the forum but couldn't find a similar topic, unfortunately.
