Audio via USB Interface
BIMM_Student
I am trying to set up audio input using a Zoom H4n which acts as a 2 channel USB interface.
When I go to the audio mixer / mic/aux properties OBS recognises the zoom OK so I can set it as input and add it as a source but I get no signal. I know the zoom is working as it has an input display I can also connect it to Reaperl. I can get audio if I select the built-in mic in the webcam. The zoom is selected as input in windows sound settings. The zoom and obs are set at 48. I had the zoom working with obs previously but I can't repeat it and I don't know where else to lookt. Many thanks.
