Audio track 2-6 doesn't work while streaming!
Jimyyez
Whenever I start streaming while my twitch audio track is on to play some music apart from the desktop audio it does not work and does not get the desktop audio into the stream at all and tried every solution with every single audio track from the Advanced tab to separate the audio from. It does not work at all only first track works and from track 2 to 6 does not work at all... I tried this a couple of times and still no audio at all...
It is normal.
  • Only one track goes to the stream (the track can be selected in main menu File>Settings>Output>Output Mode: Advanced>Streaming_tab>Audio Track - here if track is checked, means that the track# goes to output/streamed).
  • Any sources can be mixed to this track (these sources can be specified in: main menu Edit>Advanced Audio Properties>Tracks - here if checked, means that the source mixed to the track# ).
