Chuck Hast
Folks,
I am running a Blackmagic Intensity Pro 4K, I am using OBS Studio as a video
switch and converter to stream the A/V stream to Youtube. The video is working
quite well, I did have an issue with the color type, once I figured that out I no
longer have any issue there. But with the audio it stutters continuously.
The A/V stream enters the video card from a HDMI input, the analogue sound
is good or I would not be able to do the below stated kludge to get it working.
My work around has been to pull the analogue audio off of the Intensity Pro 4K
and feed it into the mic input on the computer sound card, giving me good audio.
But that is another failure point (someone pulls the cable loose) and I would rather
all of the audio path go through the computer from the sound card.
Has anyone had issues with this? I have looked at the usual places and no joy.
