Hello,
I was looking for a replacement to XSplit and found this. I like the program a lot, allows me to stream without in game lag or frame drops. There is only one problem that keeps me from streaming at all which is audio problems with my Focusrite Saffire Pro 40 audio interface.
I currently have a few problems:
- Audio clicks and cuts, this isn't reflected on stream.
- Audio starts distorting heavily and usually stays until I close all programs using audio. This is also not reflected on stream.
- Mic distortion which happens on stream and in other programs (I use TS3).
All of these only happens when I use the Saffire audio interface as default input/output device in windows. In this stream, I switch my default output to my onboard soundcard. The microphone still gets the distortion (see 14:00) while the sound I get in my headphones is perfect throughout. Since I changed the default output mid stream, the stream gets no audio other than my mic. I did a test after using my onboard soundcard as output and my Saffire as default input and didn't see any issues both locally and on stream (i listened to myself talk randomly while gaming for 17 minutes... quite painful).
Anyway, there seems to be an issue when I start the stream while using both input and output on my Saffire audio interface. I don't get any issues when only the input is on the Saffire audio interface.
Here's the logs that I have. I switched the windows default audio mid stream but that doesn't show in the logs so you'll have to trust me (or watch me for 18 minutes to see that I do it on stream) :P
Thanks for your help and time developing this kick ass software.
Open Broadcaster Software v0.466a - 32bit (´・ω・`)
CPU Name: Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
CPU Speed: 2672MHz
Physical Memory: 4095MB Total, 3801MB Free
stepping id: 5, model 10, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 8, total cores 4
Windows Version: 6.1 Build 7600
Aero is Disabled
Adapter 1
Video Adapter: ATI Radeon HD 4870
Video Adapter Dedicated Video Memory: 1064308736
Video Adapter Shared System Memory: 2948132864
Base resolution: 1920x1080
Output resolution: 1280x720
Loading up D3D10...
Using auxilary audio input: Saffire Audio (Saffire Audio)
Audio Encoding: AAC
bitrate: 128
device: Logitech HD Pro Webcam C910,
device id \\?\usb#vid_046d&pid_0821&mi_02#7&283de09f&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
chosen type: RGB24, usingFourCC: false, res: 1280x960 - 1280x960, fps: 5-15, fourCC: 00000000
Using directshow input
Using Window Capture
Using bitmap image
Video Encoding: x264
fps: 30
width: 1280, height: 720
preset: veryfast
CBR: no
max bitrate: 2500
buffer size: 2500
quality: 10
New Scene
Using graphics capture
New Scene
Using bitmap image
New Scene
Using bitmap image
New Scene
Using Monitor Capture
New Scene
Using text output
New Scene
New Scene
Using text output
New Scene
Using bitmap image
New Scene
New Scene
Using bitmap image
New Scene
New Scene
Using text output
Total frames rendered: 12588, number of frames that lagged: 39 (0.31%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
Using text output
fps: 30
preset: veryfast
CBR: no
max bitrate: 2500
buffer size: 2500
quality: 10
New Scene
Using bitmap image
Server selection: rtmp://live-iad.justin.tv/app
bufferTime: 2269, outputRateWindowTime: 1000, dropThreshold: 2769
New Scene
Using text output
New Scene
New Scene
Using bitmap image
New Scene
New Scene
Using bitmap image
New Scene
SharedTexCapture hooked
New Scene
Using bitmap image
New Scene
New Scene
Using bitmap image
New Scene
Using bitmap image
Total frames rendered: 13999, number of frames that lagged: 498 (3.56%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
Using bitmap image
fps: 30
preset: veryfast
CBR: no
max bitrate: 2500
buffer size: 2500
quality: 10
bufferTime: 2418, outputRateWindowTime: 1000, dropThreshold: 2918
Total frames rendered: 2151, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
Profiler results:
frame - [100%] [avg time: 8.199 ms] [avg calls per frame: 1] [children: 88.8%] [unaccounted: 11.2%]
| scene->Preprocess - [49.2%] [avg time: 4.033 ms] [avg calls per frame: 1]
| video encoding and uploading - [39.7%] [avg time: 3.251 ms] [avg calls per frame: 1] [children: 16.6%] [unaccounted: 23%]
| | CopyResource - [0.183%] [avg time: 0.015 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.061%] [avg time: 0.005 ms] [avg calls per frame: 0]
| | call to encoder - [16.3%] [avg time: 1.334 ms] [avg calls per frame: 0]
| | sending stuff out - [0.11%] [avg time: 0.009 ms] [avg calls per frame: 0]
