Problem118
Hi everyone,
I'm facing an issue that I thought I solved by replacing my PC hardware, but it came back and I can't pinpoint its origin.
I hear a strange audio noise/glitch only when rewatching the recordings made with OBS. It happens at irregular intervals across all games. I do NOT hear any glitching in real-time while playing, neither through my headphones nor through my speakers.
My Specs:
Any help or troubleshooting steps would be greatly appreciated!
My Specs:
- CPU: AMD Ryzen 5 9600X
- GPU: ASUS Prime RTX 5070
- Motherboard: MSI PRO B650-A WIFI
- RAM: 32 GB DDR5 CL30 6000MHz
- PSU: be quiet! Dark Power 14 850W Titanium
- Case: NZXT H9 Flow (2025)
- Audio Gear: Audient iD4 MKII Audio Interface + Shure XLR Mic
- Peripherals: Elgato Stream Deck, Keyboard, Mouse, Creative Desktop Speakers
- Temperatures and CPU/GPU usage are completely normal during gameplay.
- Running LatencyMon showed slight latency spikes in nvlddmkm.sys (Nvidia kernel mode driver), which slightly improved after updating graphics drivers.
- Audio pops are gone, but this specific noise remains in recorded files.
- Important detail: I had the exact same issue on a completely different older PC build. The only components carried over from the old build are the mouse, keyboard, Stream Deck, and the Audient iD4 interface + XLR microphone.
- Background software running: MSI Afterburner, HWInfo, Stream Deck software.
- OBS Audio Settings: 48,000 Hz sample rate across all devices and OBS settings, Audient buffer size set to 512 samples.
