Question / Help Audio Problems
KillerKorbin117
Ok so i always do a 10 second test to see if my mic volume is fine and its fine but whenever i record for a long period of time it just mutes out my mic for some reason if u need any info plz ask me and ill give it to u
Lain
Forum Admin
Lain
Forum Moderator
Developer
I can't help but wonder if you perhaps have a hotkey set to mute/unmute mic. You need to include a logfile otherwise, though.
KillerKorbin117
here:
6:28:31: Open Broadcaster Software v0.624b - 64bit ( ^ω^)
16:28:31: -------------------------------
16:28:31: CPU Name: AMD FX(tm)-8300 Eight-Core Processor
16:28:31: CPU Speed: 3311MHz
16:28:31: Physical Memory: 8107MB Total, 5989MB Free
16:28:31: stepping id: 0, model 2, family 21, type 0, extmodel 0, extfamily 3, HTT 1, logical cores 8, total cores 4
16:28:31: monitor 1: pos={0, 0}, size={1920, 1080}
16:28:31: Windows Version: 6.2 Build 9200
16:28:31: Aero is Enabled
16:28:31: OBS Modules:
16:28:31: Base Address Module
16:28:31: 00000000C28B0000 OBS.exe
16:28:31: 0000000069110000 OBSApi.dll
16:28:31: 0000000076960000 DShowPlugin.dll
16:28:31: 000000006BE80000 GraphicsCapture.dll
16:28:31: 000000006BE50000 NoiseGate.dll
16:28:31: 000000006BE20000 PSVPlugin.dll
16:28:31: ------------------------------------------
16:28:31: Adapter 1
16:28:31: Video Adapter: NVIDIA GeForce GTX 650
16:28:31: Video Adapter Dedicated Video Memory: 1012723712
16:28:31: Video Adapter Shared System Memory: 3221417984
16:28:31: Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
16:28:31: =====Stream Start: 2014-06-17, 16:28:31===============================================
16:28:31: Multithreaded optimizations: On
16:28:31: Base resolution: 1920x1080
16:28:31: Output resolution: 1920x1080
16:28:31: Loading up D3D10 on NVIDIA GeForce GTX 650 (Adapter 1)...
16:28:31: Audio Format: 44100 Hz
16:28:31: Audio Channels: 2 Ch
16:28:31: Playback device {0.0.0.00000000}.{4d882026-552f-48a7-aea8-b547d7344833}
16:28:31: Using desktop audio input: Killer's Mic! (USB PnP Audio Device)
16:28:31: Global Audio time adjust: 0
16:28:31: Using auxilary audio input: Microphone (USB PnP Audio Device)
16:28:31: Mic time offset: 0
16:28:31: Audio Encoding: AAC
16:28:31: bitrate: 320
16:28:31: Scene buffering time set to 400
16:28:31: Video Encoding: x264
16:28:31: fps: 30
16:28:31: width: 1920, height: 1080
16:28:31: preset: veryfast
16:28:31: profile: main
16:28:31: keyint: 60
16:28:31: CBR: yes
16:28:31: CFR: yes
16:28:31: max bitrate: 15000
16:28:31: buffer size: 15000
16:30:05: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:30:05: New Scene
16:30:05: Using graphics capture
16:30:23: Trying to hook process: javaw.exe
16:30:23: SharedTexCapture hooked
16:30:45: GraphicsCaptureSource::NewCapture: eliminating old capture
16:30:45: SharedTexCapture hooked
16:38:48: Total frames encoded: 18507, total frames duplicated: 16 (0.09%)
16:38:48: Total frames rendered: 18512, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
16:38:49:
16:38:49: Profiler time results:
16:38:49:
16:38:49: ==============================================================
16:38:49: video thread frame - [100%] [avg time: 1.102 ms] [children: 17.8%] [unaccounted: 82.2%]
16:38:49: | scene->Preprocess - [0.181%] [avg time: 0.002 ms]
16:38:49: | GPU download and conversion - [17.6%] [avg time: 0.194 ms] [children: 14.5%] [unaccounted: 3.09%]
16:38:49: | | flush - [12.4%] [avg time: 0.137 ms]
16:38:49: | | CopyResource - [1.63%] [avg time: 0.018 ms]
16:38:49: | | conversion to 4:2:0 - [0.454%] [avg time: 0.005 ms]
16:38:49: Convert444Threads - [100%] [avg time: 2.795 ms] [children: 99.7%] [unaccounted: 0.25%]
16:38:49: | Convert444toNV12 - [99.7%] [avg time: 2.788 ms]
16:38:49: encoder thread frame - [100%] [avg time: 4.139 ms] [children: 2.83%] [unaccounted: 97.2%]
16:38:49: | sending stuff out - [2.83%] [avg time: 0.117 ms]
16:38:49:
16:38:49:
16:38:49: Profiler CPU results:
16:38:49:
16:38:49: video thread frame - [cpu time: avg 0.521 ms, total 9656.25 ms] [avg calls per frame: 1]
16:38:49: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
16:38:49: | GPU download and conversion - [cpu time: avg 0.049 ms, total 921.875 ms] [avg calls per frame: 1]
16:38:49: | | flush - [cpu time: avg 0.042 ms, total 781.25 ms] [avg calls per frame: 1]
16:38:49: | | CopyResource - [cpu time: avg 0.005 ms, total 109.375 ms] [avg calls per frame: 1]
16:38:49: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
16:38:49: Convert444Threads - [cpu time: avg 2.685 ms, total 99328.1 ms] [avg calls per frame: 2]
16:38:49: | Convert444toNV12 - [cpu time: avg 2.683 ms, total 99250 ms] [avg calls per frame: 2]
16:38:49: encoder thread frame - [cpu time: avg 3.52 ms, total 65109.4 ms] [avg calls per frame: 1]
16:38:49: | sending stuff out - [cpu time: avg 0.085 ms, total 1578.13 ms] [avg calls per frame: 1]
16:38:49:
16:38:49: =====Stream End: 2014-06-17, 16:38:49=================================================
XD
Lain
Forum Admin
Lain
Forum Moderator
Developer
That log file was 10 minutes long. Not particularly a long capture. Is .-. what I think it is? If it is, then that's a pretty immature response. If you are upset because I didn't answer soon enough, then you have to realize we have to go through a lot of forum posts and emails every day, and that I'm also trying to spend my time actually programming sometimes as well, and if I'm lucky, maybe a little bit of time to myself per day.
Anyway, I need a longer log where the problem happens. You should again also check to make sure a hotkey isn't set to mute it in audio settings, you never did mention whether you checked that or not, it can sometimes be set by accident.
