lordkimboris
Hi!
I've been trying to get into streaming a while now, but everytime i've tried everything works fine EXCEPT for the audio quality in stream. It sounds fine on recording and in my headset but the actual stream audio turns out damp or lowered. (almost echo-ish in a way) I've also located the issue, but not why it is an actual issue. Thing is, whenever I have my surround sound enabled on my headset (logitech g633) the stream audio is faded/damp. If I turn surround off, it seems fine. I could just stream with surround off, but I also don't want to, cause the difference between sound is massive. And when hearing is required, like when playing csgo, surround is so much better. So that's why I haven't really been streaming much. I had the same issue with my old Logitech G35, so i'm not sure if it's an logitech related issue, but I haven't really seen any other reports of this issue which is why i'm posting this. I've checked all the different settings multiple times in OBS, but haven't found a solution there. Could just be cause i'm not very experienced with Audio details etc, it could also be a problem with my sound card but I doubt that considering the motherboard is relatively new and not very low end.
Anyhow I've looked around at this a while now but haven't done anything major to fix it, up until now. So if you've got any suggestions, feel free to help!
