audio problems - warbly compression sounds under water - switch to obs.
hawkie
hello! i'm trying to stream from my nintendo switch thru my macbook pro using obs but it sounds warbly and under water and
My microphone sounds fine! It's just the audio from the switch that's the problem. the issue isn't with twitch either, i hear it thru the monitor when running obs before i start the stream.
here's a clip of what it sounds like
and here's my log file
I've tried updating obs & tried running the switch thru a different thunderbolt port.
cablewise etc. I've got a elgato hd 60 x for the capture card. so it's Nintendo Switch --> hdmi (the one that came w the elgato) -> Elgato HD 60x -> usb cable to the USB 4.0 port on my macbook pro.
