Question / Help Audio problem
ForT
Hello. My problem is about the new updates... i dont know what happened but my microphone is not working abnymore.
I have Razer Megalodon 7.1 and 2 month ago everything works fine, for now i didnt use OBS and when i turned it on, there was an update, i updated it and my microphone stoped work.
I tryed to reinstall the driver, firmware updater for the headset, tryed to use different usb ports, but nothing happened. I even tryed to run 32bit version and 64bit with administrator but it still doesn't work.
log file included. please help me
  • logfile.txt
ForT
do you have a new logfile?
here u go. Still the same everything, it's just my mic and this is very strange, becouse i can record videos and mic is working there (Dxtory), i can talk in skype and teamspeak, but OBS in OBS it's not working
  • 2016-01-22-1956-19.log
dping
you are still syncing audio timestamps. turn off "use video timestamps for audio" option under advanced or audio tab. I cant recall.
as for your update, was there an update to your audio software for your razer or OBS
ForT
i tryed, same thing, i just forgot to turn it off again. There was no update for razer headphones, only for OBS
  • 2016-01-22-2014-46.log
dping
check to make sure that there is no check in the PTT key and that the settings for mic noise gate tab are not set to high. also scene buffering should be 700ms
ForT
From the hotkeys im using only start and stop stream, no PTT keyt used there. everything on None.
Noise gate also never used. I set scene buffering to 700 and nothing changed. Pushing start button>My mic in OBS volume bar is going abit up and then down and after this never going up again. Audio not controlled by skype automaticly so it cant be changed by other programs... so there is some other reason. And the mic bar is on, it's like there is no sound only, but it's working
  • 2016-01-22-2055-30.log
ForT
oh... wow, i tirned off the option Use PTT now... i thought that was on the right side u ment, and it works...omg im such a dumb... sorry and thank you very much for help my friend! we can close this
