Audio Problem
Moquai
Heyho,
since i installed Windows 11 i have a huge problem with my Audio Recording. The Voice is only recorded distorted and over a few seconds nothing is to hear.
I tried all i could do for serveral hours. 1. Changed Mic to Acuna 900 - 2. Changed all Audio Settings-3. Reinstalled a clean OBS 4. Used an older OBS Version (25.0.1) - etc etc etc
A few days ago a Windows Update solved the problem but today (3 days later) the problem occurs again. The Microfone/Aux-Audio Bar in OBS appears to record normally.
I made a Video and uploaded it to YT: https://youtu.be/3ylLylYW4gg
The Log File during the recording:
05:04:30.317: Command Line Arguments: C:\Program Files (x86)\OBS_Stream\bin\64bit\obs64.exe
05:04:30.317: CoInitializeEx succeeded: 0x00000001
05:04:30.317: CPU Name: AMD Ryzen 9 3900X 12-Core Processor
05:04:30.317: CPU Speed: 3800MHz
05:04:30.317: Physical Cores: 12, Logical Cores: 24
05:04:30.317: Physical Memory: 32681MB Total, 24478MB Free
05:04:30.317: Windows Version: 10.0 Build 22000 (release: 2009; revision: 556; 64-bit)
05:04:30.317: Running as administrator: true
05:04:30.317: Aero is Enabled (Aero is always on for windows 8 and above)
05:04:30.317: Windows 10 Gaming Features:
05:04:30.317: Game Bar: Off
05:04:30.317: Game DVR: Off
05:04:30.317: Game DVR Background Recording: Off
05:04:30.317: Game Mode: On
05:04:30.318: Sec. Software Status:
05:04:30.319: Avira Antivirus: enabled (AV)
05:04:30.319: Microsoft Defender Antivirus: disabled (AV)
05:04:30.319: Microsoft-Firewall: enabled (FW)
05:04:30.320: Current Date/Time: 2022-03-10, 05:04:30
05:04:30.320: Browser Hardware Acceleration: true
05:04:30.320: Portable mode: false
05:04:30.868: OBS 25.0.4 (64-bit, windows)
05:04:30.868: ---------------------------------
05:04:30.886: ---------------------------------
05:04:30.886: audio settings reset:
05:04:30.886: samples per sec: 48000
05:04:30.886: speakers: 2
05:04:30.888: ---------------------------------
05:04:30.888: Initializing D3D11...
05:04:30.888: Available Video Adapters:
05:04:30.890: Adapter 0: NVIDIA GeForce RTX 2080 SUPER
05:04:30.890: Dedicated VRAM: 4104126464
05:04:30.890: Shared VRAM: 4249655296
05:04:30.890: PCI ID: 10de:1e81
05:04:30.890: Driver Version: 30.0.15.1179
05:04:30.891: output 0: pos={0, 0}, size={3840, 2160}, attached=true, refresh=60, name=U28E590
05:04:30.891: output 1: pos={3840, 4}, size={3840, 2160}, attached=true, refresh=60, name=U28E590
05:04:30.891: output 2: pos={-2560, 492}, size={2560, 1080}, attached=true, refresh=60, name=LG ULTRAWIDE
05:04:30.894: Loading up D3D11 on adapter NVIDIA GeForce RTX 2080 SUPER (0)
05:04:31.015: D3D11 loaded successfully, feature level used: b000
05:04:31.015: DXGI increase maximum frame latency success
05:04:31.018: D3D11 GPU priority setup success
05:04:31.472: ---------------------------------
05:04:31.472: video settings reset:
05:04:31.472: base resolution: 1920x1080
05:04:31.472: output resolution: 1920x1080
05:04:31.472: downscale filter: Lanczos
05:04:31.472: fps: 30/1
05:04:31.472: format: NV12
05:04:31.472: YUV mode: 601/Partial
05:04:31.472: NV12 texture support enabled
05:04:31.474: Audio monitoring device:
05:04:31.474: name: Standard
05:04:31.474: id: default
05:04:31.475: ---------------------------------
05:04:31.478: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
05:04:31.479: Failed to load 'en-US' text for module: 'decklink-ouput-ui.dll'
05:04:31.521: [AMF] Unable to load 'amfrt64.dll', error code 126.
05:04:31.523: [AMF] AMF Test failed due to one or more errors.
05:04:31.523: Failed to initialize module 'enc-amf.dll'
05:04:31.544: [obs-browser]: Version 2.8.6
05:04:31.548: NVENC supported
05:04:32.041: VLC found, VLC video source enabled
05:04:32.047: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
05:04:32.048: No blackmagic support
05:04:32.052: ---------------------------------
05:04:32.052: Loaded Modules:
05:04:32.052: win-wasapi.dll
05:04:32.052: win-mf.dll
05:04:32.052: win-dshow.dll
05:04:32.052: win-decklink.dll
05:04:32.052: win-capture.dll
05:04:32.052: vlc-video.dll
05:04:32.052: text-freetype2.dll
05:04:32.052: rtmp-services.dll
05:04:32.052: obs-x264.dll
05:04:32.052: obs-vst.dll
05:04:32.052: obs-transitions.dll
05:04:32.052: obs-text.dll
05:04:32.052: obs-qsv11.dll
05:04:32.052: obs-outputs.dll
05:04:32.052: obs-filters.dll
05:04:32.052: obs-ffmpeg.dll
05:04:32.052: obs-browser.dll
05:04:32.052: image-source.dll
05:04:32.052: frontend-tools.dll
05:04:32.052: enc-amf.dll
05:04:32.052: decklink-ouput-ui.dll
05:04:32.052: coreaudio-encoder.dll
05:04:32.052: ==== Startup complete ===============================================
05:04:32.053: Service '' not found
05:04:32.057: All scene data cleared
05:04:32.057: ------------------------------------------------
05:04:32.079: WASAPI: Device 'Lautsprecher (Realtek(R) Audio)' [48000 Hz] initialized
05:04:32.097: WASAPI: Device 'Mikrofon (HyperX Quadcast)' [48000 Hz] initialized
05:04:32.098: Switched to scene 'Szene'
05:04:32.098: ------------------------------------------------
05:04:32.098: Loaded scenes:
05:04:32.098: - scene 'Szene':
05:04:32.098: - source: 'Videoaufnahmegerät' (dshow_input)
05:04:32.146: adding 42 milliseconds of audio buffering, total audio buffering is now 42 milliseconds (source: Mikrofon/AUX‐Audio)
05:04:32.146:
05:04:32.373: ---------------------------------
05:04:32.373: [DShow Device: 'Videoaufnahmegerät'] settings updated:
05:04:32.373: video device: Elgato Facecam
05:04:32.373: video path: \\?\usb#vid_0fd9&pid_0078&mi_00#7&11d0956a&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global
05:04:32.373: resolution: 1920x1080
05:04:32.373: flip: 0
05:04:32.373: fps: 60.00 (interval: 166666)
05:04:32.373: format: UYVY
05:05:01.055: [jim-nvenc: 'streaming_h264'] settings:
05:05:01.055: rate_control: CBR
05:05:01.055: bitrate: 2500
05:05:01.055: cqp: 20
05:05:01.055: keyint: 250
05:05:01.055: preset: hq
05:05:01.055: profile: high
05:05:01.055: width: 1920
05:05:01.055: height: 1080
05:05:01.055: 2-pass: false
05:05:01.055: b-frames: 2
05:05:01.055: lookahead: false
05:05:01.055: psycho_aq: true
05:05:01.055:
05:05:01.098: ---------------------------------
05:05:01.099: [FFmpeg aac encoder: 'Track1'] bitrate: 160, channels: 2, channel_layout: 3
05:05:01.099:
05:05:01.121: ==== Recording Start ===============================================
05:05:01.121: [ffmpeg muxer: 'adv_file_output'] Writing file 'C:/Users/svens/Videos/2022-03-10 05-05-00.mkv'...
05:06:17.140: [ffmpeg muxer: 'adv_file_output'] Output of file 'C:/Users/svens/Videos/2022-03-10 05-05-00.mkv' stopped
05:06:17.140: Output 'adv_file_output': stopping
05:06:17.140: Output 'adv_file_output': Total frames output: 2272
05:06:17.140: Output 'adv_file_output': Total drawn frames: 2280
05:06:17.140: ==== Recording Stop ================================================
05:06:17.273: warning: 2 frames left in the queue on closing
I hope anyone can help
