Question / Help Audio problem...
Dyexz
I've been trying to setup a live video stream, but don't want the desktop sounds to be streamed along with the video feed. on the other hand I still wish for the game sound and other sounds when using "Game Recorder/Steam" to be streamed.
removing the desktop sounds is pretty easy to get rid of it's just to pick a unused Audio output device in the sound settings, but then the problem is that you won't be able to get any sounds from your sources (game-clients or programs like winamp or other).
any chance that there's a workaround or something to this problem ?
dodgepong
Administrator
Community Helper
If you can't change the audio output device of the game, then no, there is not. Either you get all the sounds from your default output device, or you get none. You can try changing the audio device of everything else instead.
