Question / Help Audio problem (distorted bass)
Roemerbo
Hi there,
I downloaded OBS just yesterday and when I tried streaming I noticed that the bass gets heavily distorted and it gets very noisy.
My microphone is disabled.
I would really appreciate if you could help me figure out the problem.
Here is the log:
15:03:16: Open Broadcaster Software v0.522b - 64bit ( ^ω^)
15:03:16: -------------------------------
15:03:16: CPU Name: Intel(R) Core(TM) i7-3630QM CPU @ 2.40GHz
15:03:16: CPU Speed: 2395MHz
15:03:16: Physical Memory:  8077MB Total, 4367MB Free
15:03:16: stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
15:03:16: monitor 1: pos={0, 0}, size={1920, 1080}
15:03:16: Windows Version: 6.2 Build 9200
15:03:16: Aero is Enabled
15:03:16: OBS Modules:
15:03:16: Base Address     Module
15:03:16: 00000000C64D0000 OBS.exe
15:03:16: 00000000FEA30000 OBSApi.dll
15:03:16: 00000000160C0000 DShowPlugin.dll
15:03:16: 0000000013CA0000 GraphicsCapture.dll
15:03:16: 0000000014470000 NoiseGate.dll
15:03:16: ------------------------------------------
15:03:16: Adapter 1
15:03:16:   Video Adapter: Intel(R) HD Graphics 4000
15:03:16:   Video Adapter Dedicated Video Memory: 33554432
15:03:16:   Video Adapter Shared System Memory: 1711276032
15:03:16: Adapter 2
15:03:16:   Video Adapter: NVIDIA GeForce GT 635M
15:03:16:   Video Adapter Dedicated Video Memory: 2096693248
15:03:16:   Video Adapter Shared System Memory: 2147495936
15:03:16: =====Stream Start: 2013-06-07, 15:03:16===============================================
15:03:16:   Multithreaded optimizations: On
15:03:16:   Base resolution: 1920x1080
15:03:16:   Output resolution: 960x540
15:03:16: Loading up D3D10...
15:03:16: Playback device Default
15:03:16: Using desktop audio input: Speakers (Realtek High Definition Audio)
15:03:16: Audio Encoding: MP3
15:03:16:     bitrate: 128
15:03:16: Using bitmap image
15:03:16: Video Encoding: x264
15:03:16:     fps: 30
15:03:16:     width: 960, height: 540
15:03:16:     preset: medium
15:03:16:     CBR: yes
15:03:16:     CFR: no
15:03:16:     max bitrate: 900
15:03:19: Using RTMP service: Twitch / Justin.tv
15:03:19:   Server selection: rtmp://live-lhr.justin.tv/app
15:03:20: SO_SNDBUF was at 65536
15:03:20: SO_SNDBUF is now 65536
15:03:34: RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 131072
15:04:16: Total frames rendered: 1803, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
15:04:16: RTMPPublisher::SocketLoop: Aborting due to loop exit
15:04:16: librtmp error: WriteN, RTMP send error 10035 (79 bytes)
15:04:16: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
15:04:16: Number of times waited to send: 11, Waited for a total of 41449 bytes
15:04:16: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
15:04:16: =====Stream End: 2013-06-07, 15:04:16=================================================
15:19:53: =====Stream Start: 2013-06-07, 15:19:53===============================================
15:19:53:   Multithreaded optimizations: On
15:19:53:   Base resolution: 1920x1080
15:19:53:   Output resolution: 960x540
15:19:53: ------------------------------------------
15:19:53: Loading up D3D10...
15:19:53: Playback device Default
15:19:53: Using desktop audio input: Speakers (Realtek High Definition Audio)
15:19:53: Audio Encoding: MP3
15:19:53:     bitrate: 128
15:19:53: Using bitmap image
15:19:53: Video Encoding: x264
15:19:53:     fps: 30
15:19:53:     width: 960, height: 540
15:19:53:     preset: medium
15:19:53:     CBR: yes
15:19:53:     CFR: no
15:19:53:     max bitrate: 900
15:19:56: Using RTMP service: Twitch / Justin.tv
15:19:56:   Server selection: rtmp://live-lhr.justin.tv/app
15:19:57: SO_SNDBUF was at 65536
15:19:57: SO_SNDBUF is now 65536
15:20:29: RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 262144
15:20:45: Total frames rendered: 1570, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
15:20:45: RTMPPublisher::SocketLoop: Aborting due to loop exit
15:20:45: librtmp error: WriteN, RTMP send error 10035 (79 bytes)
15:20:45: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
15:20:45: Number of times waited to send: 7, Waited for a total of 26427 bytes
15:20:45: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
15:20:45: =====Stream End: 2013-06-07, 15:20:45=================================================
15:23:35: =====Stream Start: 2013-06-07, 15:23:35===============================================
15:23:35:   Multithreaded optimizations: On
15:23:35:   Base resolution: 1920x1080
15:23:35:   Output resolution: 960x540
15:23:35: ------------------------------------------
15:23:35: Loading up D3D10...
15:23:35: Playback device Default
15:23:35: Using desktop audio input: Speakers (Realtek High Definition Audio)
15:23:35: Audio Encoding: MP3
15:23:35:     bitrate: 128
15:23:35: Using bitmap image
15:23:35: Video Encoding: x264
15:23:35:     fps: 30
15:23:35:     width: 960, height: 540
15:23:35:     preset: medium
15:23:35:     CBR: yes
15:23:35:     CFR: no
15:23:35:     max bitrate: 900
15:23:37: Using RTMP service: Twitch / Justin.tv
15:23:37:   Server selection: rtmp://live-lhr.justin.tv/app
15:23:39: SO_SNDBUF was at 65536
15:23:39: SO_SNDBUF is now 65536
15:24:38: Total frames rendered: 1891, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
15:24:38: RTMPPublisher::SocketLoop: Aborting due to bStopping
15:24:38: Number of times waited to send: 0, Waited for a total of 0 bytes
15:24:38: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
15:24:38: =====Stream End: 2013-06-07, 15:24:38=================================================
16:22:38: =====Stream Start: 2013-06-07, 16:22:38===============================================
16:22:38:   Multithreaded optimizations: On
16:22:38:   Base resolution: 1920x1080
16:22:38:   Output resolution: 960x540
16:22:38: ------------------------------------------
16:22:38: Loading up D3D10...
16:22:39: Playback device Default
16:22:39: ------------------------------------------
16:22:39: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:22:39: Audio Encoding: MP3
16:22:39:     bitrate: 128
16:22:39: Using bitmap image
16:22:39: Video Encoding: x264
16:22:39:     fps: 30
16:22:39:     width: 960, height: 540
16:22:39:     preset: medium
16:22:39:     CBR: yes
16:22:39:     CFR: no
16:22:39:     max bitrate: 900
16:22:41: Using RTMP service: Twitch / Justin.tv
16:22:41:   Server selection: rtmp://live-lhr.justin.tv/app
16:22:43: SO_SNDBUF was at 65536
16:22:43: SO_SNDBUF is now 65536
16:23:09: Total frames rendered: 900, number of frames that lagged: 1 (0.11%) (it's okay for some frames to lag)
16:23:09: RTMPPublisher::SocketLoop: Aborting due to bStopping
16:23:09: Number of times waited to send: 0, Waited for a total of 0 bytes
16:23:09: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
16:23:09: =====Stream End: 2013-06-07, 16:23:09=================================================
16:24:43: =====Stream Start: 2013-06-07, 16:24:43===============================================
16:24:43:   Multithreaded optimizations: On
16:24:43:   Base resolution: 1920x1080
16:24:43:   Output resolution: 960x540
16:24:43: ------------------------------------------
16:24:43: Loading up D3D10...
16:24:43: Playback device Default
16:24:43: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:24:43: Audio Encoding: MP3
16:24:43:     bitrate: 128
16:24:43: Using bitmap image
16:24:43: Video Encoding: x264
16:24:43:     fps: 30
16:24:43:     width: 960, height: 540
16:24:43:     preset: medium
16:24:43:     CBR: yes
16:24:43:     CFR: no
16:24:43:     max bitrate: 900
16:24:46: Using RTMP service: Twitch / Justin.tv
16:24:46:   Server selection: rtmp://live-lhr.justin.tv/app
16:24:47: SO_SNDBUF was at 65536
16:24:47: SO_SNDBUF is now 65536
16:25:16: Total frames rendered: 988, number of frames that lagged: 1 (0.10%) (it's okay for some frames to lag)
16:25:16: RTMPPublisher::SocketLoop: Aborting due to bStopping
16:25:16: Number of times waited to send: 0, Waited for a total of 0 bytes
16:25:16: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
16:25:16: =====Stream End: 2013-06-07, 16:25:16=================================================
16:31:18: =====Stream Start: 2013-06-07, 16:31:18===============================================
16:31:18:   Multithreaded optimizations: On
16:31:18:   Base resolution: 1920x1080
16:31:18:   Output resolution: 960x540
16:31:18: ------------------------------------------
16:31:18: Loading up D3D10...
16:31:18: Playback device Default
16:31:18: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:31:18: Audio Encoding: MP3
16:31:18:     bitrate: 128
16:31:18: Using bitmap image
16:31:18: Video Encoding: x264
16:31:18:     fps: 30
16:31:18:     width: 960, height: 540
16:31:18:     preset: medium
16:31:18:     CBR: yes
16:31:18:     CFR: no
16:31:18:     max bitrate: 900
16:31:21: Using RTMP service: Twitch / Justin.tv
16:31:21:   Server selection: rtmp://live-lhr.justin.tv/app
16:31:22: SO_SNDBUF was at 65536
16:31:22: SO_SNDBUF is now 65536
16:32:12: Total frames rendered: 1622, number of frames that lagged: 2 (0.12%) (it's okay for some frames to lag)
16:32:12: RTMPPublisher::SocketLoop: Aborting due to bStopping
16:32:12: Number of times waited to send: 0, Waited for a total of 0 bytes
16:32:12: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
16:32:13: =====Stream End: 2013-06-07, 16:32:13=================================================
16:35:29: =====Stream Start: 2013-06-07, 16:35:29===============================================
16:35:29:   Multithreaded optimizations: On
16:35:29:   Base resolution: 1920x1080
16:35:29:   Output resolution: 960x540
16:35:29: ------------------------------------------
16:35:29: Loading up D3D10...
16:35:29: Playback device Default
16:35:29: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:35:29: Audio Encoding: MP3
16:35:29:     bitrate: 128
16:35:29: Using bitmap image
16:35:29: Using graphics capture
16:35:29: Video Encoding: x264
16:35:29:     fps: 30
16:35:29:     width: 960, height: 540
16:35:29:     preset: medium
16:35:29:     CBR: yes
16:35:29:     CFR: no
16:35:29:     max bitrate: 900
16:35:34: SharedTexCapture hooked
16:35:51: GraphicsCaptureSource::NewCapture:  eliminating old capture
16:35:51: SharedTexCapture hooked
16:38:11: Total frames rendered: 4844, number of frames that lagged: 21 (0.43%) (it's okay for some frames to lag)
16:38:11: =====Stream End: 2013-06-07, 16:38:11=================================================
16:40:19: =====Stream Start: 2013-06-07, 16:40:19===============================================
16:40:19:   Multithreaded optimizations: On
16:40:19:   Base resolution: 1920x1080
16:40:19:   Output resolution: 960x540
16:40:19: ------------------------------------------
16:40:19: Loading up D3D10...
16:40:19: Playback device Default
16:40:19: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:40:19: Audio Encoding: MP3
16:40:19:     bitrate: 128
16:40:19: Using bitmap image
16:40:19: Using graphics capture
16:40:19: Video Encoding: x264
16:40:19:     fps: 30
16:40:19:     width: 960, height: 540
16:40:19:     preset: medium
16:40:19:     CBR: yes
16:40:19:     CFR: no
16:40:19:     max bitrate: 900
16:40:30: SharedTexCapture hooked
16:43:08: Total frames rendered: 5067, number of frames that lagged: 2 (0.04%) (it's okay for some frames to lag)
16:43:08: =====Stream End: 2013-06-07, 16:43:08=================================================
16:43:11: =====Stream Start: 2013-06-07, 16:43:11===============================================
16:43:11:   Multithreaded optimizations: On
16:43:11:   Base resolution: 1920x1080
16:43:11:   Output resolution: 960x540
16:43:11: ------------------------------------------
16:43:11: Loading up D3D10...
16:43:11: Playback device Default
16:43:11: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:43:11: Audio Encoding: MP3
16:43:11:     bitrate: 128
16:43:11: Using bitmap image
16:43:11: Using graphics capture
16:43:11: Video Encoding: x264
16:43:11:     fps: 30
16:43:11:     width: 960, height: 540
16:43:11:     preset: medium
16:43:11:     CBR: yes
16:43:11:     CFR: no
16:43:11:     max bitrate: 900
16:43:13: Using RTMP service: Twitch / Justin.tv
16:43:13:   Server selection: rtmp://live-lhr.justin.tv/app
16:43:15: SO_SNDBUF was at 65536
16:43:15: SO_SNDBUF is now 65536
16:43:15: SharedTexCapture hooked
16:43:46: Total frames rendered: 1064, number of frames that lagged: 1 (0.09%) (it's okay for some frames to lag)
16:43:46: RTMPPublisher::SocketLoop: Aborting due to bStopping
16:43:46: Number of times waited to send: 0, Waited for a total of 0 bytes
16:43:46: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
16:43:46: =====Stream End: 2013-06-07, 16:43:46=================================================
16:45:32: =====Stream Start: 2013-06-07, 16:45:32===============================================
16:45:32:   Multithreaded optimizations: On
16:45:32:   Base resolution: 1920x1080
16:45:32:   Output resolution: 960x540
16:45:32: ------------------------------------------
16:45:32: Loading up D3D10...
16:45:32: Playback device Default
16:45:32: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:45:32: Audio Encoding: MP3
16:45:32:     bitrate: 128
16:45:32: Using bitmap image
16:45:32: Using graphics capture
16:45:32: Video Encoding: x264
16:45:32:     fps: 30
16:45:32:     width: 960, height: 540
16:45:32:     preset: medium
16:45:32:     CBR: yes
16:45:32:     CFR: no
16:45:32:     max bitrate: 900
16:45:35: SharedTexCapture hooked
16:45:35: Using RTMP service: Twitch / Justin.tv
16:45:35:   Server selection: rtmp://live-lhr.justin.tv/app
16:45:36: SO_SNDBUF was at 65536
16:45:36: SO_SNDBUF is now 65536
16:46:19: Total frames rendered: 1408, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
16:46:19: RTMPPublisher::SocketLoop: Aborting due to bStopping
16:46:19: Number of times waited to send: 0, Waited for a total of 0 bytes
16:46:19: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
16:46:19: =====Stream End: 2013-06-07, 16:46:19=================================================
16:49:52:
16:49:52: Profiler results:
16:49:52:
16:49:52: ==============================================================
16:49:52: frame - [100%] [avg time: 1.896 ms] [avg calls per frame: 1] [children: 54.3%] [unaccounted: 45.7%]
16:49:52: | scene->Preprocess - [0.105%] [avg time: 0.002 ms] [avg calls per frame: 1]
16:49:52: | video encoding and uploading - [54.2%] [avg time: 1.028 ms] [avg calls per frame: 1] [children: 51.3%] [unaccounted: 2.9%]
16:49:52: | | CopyResource - [1%] [avg time: 0.019 ms] [avg calls per frame: 0]
16:49:52: | | conversion to 4:2:0 - [0.211%] [avg time: 0.004 ms] [avg calls per frame: 0]
16:49:52: | | call to encoder - [49.7%] [avg time: 0.943 ms] [avg calls per frame: 0]
16:49:52: | | sending stuff out - [0.369%] [avg time: 0.007 ms] [avg calls per frame: 0]
16:49:52:
Here are some examples: (MIND YOUR EARS!)
Music + game:
http://www.twitch.tv/roemerbo/b/413793626
Game:
http://www.twitch.tv/roemerbo/b/413792786
Bass heavy music:
http://www.twitch.tv/roemerbo/b/413789240
http://www.twitch.tv/roemerbo/b/413786308
