Audio plays through desktop and microphone
mrageless
I've been having a recurring problem of my desktop audio playing through both my desktop audio tab and the microphone tab. It's not bleeding in, sound is just being picked up by the mic, the audio from my game is fully playing through both the the desktop audio and microphone. When I stream or record like this, there are two distinct tracks playing which causes a pretty rough echo. Sometimes while I'm trying to fix it, it will stop happening and sound will only come through the desktop audio and the mic will work properly. More often than not though, after a minute or two of running OBS, the two tracks will separate and my mic will stop picking up desktop audio. I uninstalled and reinstalled OBS and I've tried a lot of fixes that other people reported, but it doesn't seem like anyone else has had this problem. Most people with similar problems have an issue with their mic picking up the audio as it comes out of their pc. However, mine is running the audio through both channels simultaneously. It's probably a simple fix, but I've tried everything I could find and it hasn't fixed it yet. So, how do I get my audio to only play through my desktop audio channel and not through desktop audio and mic together. Also, here's an image showing both audio bars engaged in the current track. https://imgur.com/a/nUlmF9X
07:09:54.655: Command Line Arguments: C:\Program Files\obs-studio\bin\64bit\obs64.exe
07:09:54.655: CPU Name: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
07:09:54.655: CPU Speed: 1800MHz
07:09:54.656: Physical Cores: 4, Logical Cores: 8
07:09:54.656: Physical Memory: 8078MB Total, 4027MB Free
07:09:54.656: Windows Version: 10.0 Build 19044 (release: 21H2; revision: 2130; 64-bit)
07:09:54.656: Running as administrator: false
07:09:54.656: Windows 10/11 Gaming Features:
07:09:54.656: Game Bar: Off
07:09:54.656: Game DVR: Off
07:09:54.656: Game DVR Background Recording: Off
07:09:54.663: Game Mode: Probably On (no reg key set)
07:09:54.665: Sec. Software Status:
07:09:54.666: Microsoft Defender Antivirus: temporarily disabled (AV)
07:09:54.667: Windows Firewall: enabled (FW)
07:09:54.668: Current Date/Time: 2023-02-19, 07:09:54
07:09:54.668: Browser Hardware Acceleration: true
07:09:54.668: Hide OBS windows from screen capture: false
07:09:54.668: Qt Version: 6.3.1 (runtime), 6.3.1 (compiled)
07:09:54.668: Portable mode: false
07:09:55.024: OBS 29.0.2 (64-bit, windows)
07:09:55.024: ---------------------------------
07:09:55.046: ---------------------------------
07:09:55.046: audio settings reset:
07:09:55.046: samples per sec: 48000
07:09:55.046: speakers: 1
07:09:55.046: max buffering: 960 milliseconds
07:09:55.046: buffering type: dynamically increasing
07:09:55.047: ---------------------------------
07:09:55.047: Initializing D3D11...
07:09:55.047: Available Video Adapters:
07:09:55.048: Adapter 0: Intel(R) UHD Graphics 620
07:09:55.048: Dedicated VRAM: 134217728
07:09:55.048: Shared VRAM: 4235610112
07:09:55.048: PCI ID: 8086:5917
07:09:55.049: Driver Version: 27.20.100.8682
07:09:55.049: output 0:
07:09:55.049: name=
07:09:55.049: pos={0, 0}
07:09:55.049: size={1920, 1080}
07:09:55.049: attached=true
07:09:55.049: refresh=60
07:09:55.049: bits_per_color=8
07:09:55.049: space=RGB_FULL_G22_NONE_P709
07:09:55.049: sdr_white_nits=80
07:09:55.049: nit_range=[min=0.500000, max=270.000000, max_full_frame=270.000000]
07:09:55.051: Loading up D3D11 on adapter Intel(R) UHD Graphics 620 (0)
07:09:55.235: D3D11 loaded successfully, feature level used: b000
07:09:55.235: DXGI increase maximum frame latency success
07:09:56.806: ---------------------------------
07:09:56.806: video settings reset:
07:09:56.806: base resolution: 1280x720
07:09:56.806: output resolution: 1280x720
07:09:56.806: downscale filter: Bicubic
07:09:56.806: fps: 60/1
07:09:56.806: format: NV12
07:09:56.806: YUV mode: Rec. 709/Partial
07:09:56.806: NV12 texture support enabled
07:09:56.806: P010 texture support not available
07:09:56.807: Audio monitoring device:
07:09:56.807: name: Default
07:09:56.807: id: default
07:09:56.807: ---------------------------------
07:09:56.810: No AJA devices found, skipping loading AJA UI plugin
07:09:56.810: Failed to initialize module 'aja-output-ui.dll'
07:09:56.812: No AJA devices found, skipping loading AJA plugin
07:09:56.812: Failed to initialize module 'aja.dll'
07:09:56.812: Skipping module '../../obs-plugins/64bit/chrome_elf.dll', not an OBS plugin
07:09:56.815: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
07:09:56.815: Failed to load 'en-US' text for module: 'decklink-captions.dll'
07:09:56.816: Failed to load 'en-US' text for module: 'decklink-output-ui.dll'
07:09:56.818: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
07:09:56.818: Failed to initialize module 'decklink.dll'
07:09:56.846: [AMF] Unable to load 'amfrt64.dll', error code 126.
07:09:56.848: [AMF] AMF Test failed due to one or more errors.
07:09:56.848: Failed to initialize module 'enc-amf.dll'
07:09:56.860: Skipping module '../../obs-plugins/64bit/libcef.dll', not an OBS plugin
07:09:56.860: Skipping module '../../obs-plugins/64bit/libEGL.dll', not an OBS plugin
07:09:56.860: Skipping module '../../obs-plugins/64bit/libGLESv2.dll', not an OBS plugin
07:09:56.872: [obs-browser]: Version 2.19.0
07:09:56.872: [obs-browser]: CEF Version 103.0.5060.134 (runtime), 103.0.0-5060-shared-textures.2591+g4204d54+chromium-103.0.5060.134 (compiled)
07:09:56.876: [noise suppress]: NVIDIA denoiser disabled, redistributable not found or could not be loaded.
07:09:56.877: Failed to get NVVideoEffects.dll version info size
07:09:56.879: [NVIDIA VIDEO FX]: FX disabled, redistributable not found or could not be loaded.
07:09:57.086: [obs-websocket] [obs_module_load] you can haz websockets (Version: 5.1.0 | RPC Version: 1)
07:09:57.086: [obs-websocket] [obs_module_load] Qt version (compile-time): 6.3.1 | Qt version (run-time): 6.3.1
07:09:57.086: [obs-websocket] [obs_module_load] Linked ASIO Version: 101201
07:09:57.100: [obs-websocket] [obs_module_load] Module loaded.
07:09:57.107: [vlc-video]: VLC 3.0.10 Vetinari found, VLC video source enabled
07:09:57.114: ---------------------------------
07:09:57.114: Loaded Modules:
07:09:57.114: win-wasapi.dll
07:09:57.114: win-mf.dll
07:09:57.114: win-dshow.dll
07:09:57.114: win-capture.dll
07:09:57.114: vlc-video.dll
07:09:57.114: text-freetype2.dll
07:09:57.114: rtmp-services.dll
07:09:57.114: obs-x264.dll
07:09:57.114: obs-websocket.dll
07:09:57.114: obs-vst.dll
07:09:57.114: obs-transitions.dll
07:09:57.114: obs-text.dll
07:09:57.114: obs-qsv11.dll
07:09:57.114: obs-outputs.dll
07:09:57.114: obs-filters.dll
07:09:57.114: obs-ffmpeg.dll
07:09:57.114: obs-browser.dll
07:09:57.114: image-source.dll
07:09:57.114: frontend-tools.dll
07:09:57.114: decklink-output-ui.dll
07:09:57.114: decklink-captions.dll
07:09:57.114: coreaudio-encoder.dll
07:09:57.115: ==== Startup complete ===============================================
07:09:57.181: All scene data cleared
07:09:57.181: ------------------------------------------------
07:09:57.207: [win-wasapi: 'Desktop Audio'] update settings:
07:09:57.207: device id: {0.0.0.00000000}.{5851047a-31e3-43e2-bbd9-bb32170dfcb2}
07:09:57.207: use device timing: 1
07:09:57.216: [Loaded global audio device]: 'Desktop Audio'
07:09:57.216: - monitoring: monitor and output
07:09:57.216: [win-wasapi: 'Mic/Aux'] update settings:
07:09:57.216: device id: {0.0.1.00000000}.{1326a695-573a-4836-aa5f-f7d5a4f1e537}
07:09:57.216: use device timing: 0
07:09:57.217: [noise suppress: 'Noise Suppression'] NVAFX redist is not installed.
07:09:57.217: [Loaded global audio device]: 'Mic/Aux'
07:09:57.217: - filter: 'Noise Gate' (noise_gate_filter)
07:09:57.218: - filter: 'Noise Suppression' (noise_suppress_filter_v2)
07:09:57.322: WASAPI: Device 'Microphone (Conexant SmartAudio HD)' [48000 Hz] initialized
07:09:57.340: WASAPI: Device 'Speakers (Conexant SmartAudio HD)' [48000 Hz] initialized
07:09:57.372: adding 64 milliseconds of audio buffering, total audio buffering is now 64 milliseconds (source: Mic/Aux)
07:09:57.372:
07:09:57.577: Video Capture Device 2: data.GetDevice failed
07:09:57.577: Video Capture Device 2: Video configuration failed
07:09:58.822: [window-capture: 'Biz'] update settings:
07:09:58.822: executable: EmuHawk.exe
07:09:58.822: method selected: Automatic
07:09:58.822: method chosen: BitBlt
07:09:58.822:
07:09:58.847: [window-capture: 'LiveSplit'] update settings:
07:09:58.847: executable: LiveSplit.exe
07:09:58.847: method selected: Automatic
07:09:58.847: method chosen: BitBlt
07:09:58.847:
07:09:58.884: warning: deprecated pixel format used, make sure you did set range correctly
07:09:58.909: Switched to scene 'Scene'
07:09:58.909: ------------------------------------------------
07:09:58.909: Loaded scenes:
07:09:58.909: - scene 'Scene':
07:09:58.919: - source: 'Biz' (window_capture)
07:09:58.919: - filter: 'Sharpen' (sharpness_filter_v2)
07:09:58.919: - filter: 'Color Key' (color_key_filter_v2)
07:09:58.920: - filter: 'Crop/Pad' (crop_filter)
07:09:58.920: - source: 'Game Capture' (game_capture)
07:09:58.920: - source: 'Video Capture Device 2' (dshow_input)
07:09:58.920: - filter: 'Color Key' (color_key_filter_v2)
07:09:58.920: - filter: 'Sharpen' (sharpness_filter_v2)
07:09:58.920: - filter: 'Color Correction' (color_filter_v2)
07:09:58.920: - source: 'LiveSplit' (window_capture)
07:09:58.920: - source: 'Wizardry cover art' (image_source)
07:09:58.920: - source: 'Chat' (browser_source)
07:09:58.920: - source: 'Might and Magic 1 Box Art' (image_source)
07:09:58.920: - source: 'Desktop Audio' (wasapi_output_capture)
07:09:58.920: - monitoring: monitor and output
07:09:58.920: - source: 'Image' (image_source)
07:09:58.920: ------------------------------------------------
07:12:10.526: User changed audio monitoring for source 'Mic/Aux' to: monitor only
07:12:14.252: User changed audio monitoring for source 'Mic/Aux' to: monitor and output
07:12:17.730: User changed audio monitoring for source 'Mic/Aux' to: none
07:12:19.917: User changed audio monitoring for source 'Desktop Audio' to: none
07:12:24.020: User changed audio monitoring for source 'Desktop Audio' to: monitor only
07:12:26.749: User changed audio monitoring for source 'Desktop Audio' to: monitor and output
I have a similar issue with a capture card at the moment, It will double play audio when i use voicemeeter and obs, I have to mute obs in the app to prevent from hearing the double desktop audio... but i lose alert sounds.
mine got solved messing with the audio monitoring device for whatever, but also a lot of my audio settings got messed up at the same time. do you use a capture as well?
I think this only happens when I'm using a window capture from my pc, the 'Biz' source above. The other day it occurred during the middle of a stream, and I had to shut off the mic.
Some updates: I haven't had the problem for a week, but it happened again today. Usually it resolves itself pretty quickly, but today it's persisting through several restarts of OBS. However, I did some more testing. While this is happening the microphone doesn't pick up my voice at all, and it only sporadically picks up any sound from my pc audio. It happens on all applications, not just the Biz application. Even if I disable desktop audio on OBS, the microphone sound bar will still be playing at full volume, just like it's the desktop audio bar, but it only records sporadic clips of noise when I do that.
