Hi there,
Just a quick question between these two options - I alternate between using an Elgato HD60 and the OG GCHD, and while I can use the capture audio only mode with the HD60, when I attempt to do the same with the GCHD, I get intermittent audio crackling in my headphones from the console, and all audio streamed out is affected when checking back the VOD. The way around it, is to send audio to the Desktop, which is fine, but I would like to have the option to adjust the GCHD levels in the mixer.
My question is: is the ~1450ms delay required for the GCHD for sync filling the buffer, which is causing the crackles? Is there a way to increase the size of the buffer? Further to that point - is there a reason when the audio comes through the Desktop, there's no issue whatsoever?
