ToTheLifeboats
Under Advance Audio Properties > Audio Monitoring - My outputs are set to Monitor Only (Mute Output) because I feed them to my Rodecaster and control levels there and then pickup the final mix from the rodecaster back to OBS (and other feeds) for broadcast.
The problem is, the settings stop working and before every show I have to go in and click the audio sources to monitor off and then back to Monitor only (mute output) for each scene and it starts working again. It does this even if I leave the program open.
I made a simple video showing the problem: https://youtu.be/JtKPEzH2TKY
Log file: https://obsproject.com/logs/Oof_S8rU3PMPUWv1
