Audio Monitoring Issue - Monitoring audio stops on loop.
Surcarance
Greetings,
I am seeing a strange audio monitoring issue when a music source loops. The first time it plays just fine and I can hear the monitoring. However after it loops, the monitoring stops where I can not hear it anymore. I can "correct" this by going to my Settings -> Audio -> Monitoring Device and switching it out for the "same" item. Example: Changing from Speakers -->Default( Apply ) and the sound works then, I can then switch back by going Default -> Speakers (Apply) and the monitoring continues to work just fine, until the Music track loops again. This does mot effect the audio being played to my stream. That works just fine, Just the monitoring.
Log File Link: https://obsproject.com/logs/TrXr2AThLehClt2T
Thanks!
waynieoaks
Hi
For anyone else facing this issue, I have managed to get around it by using the Audio Monitor plugin:
