LordSearinex
I've been dealing with the bug for a while and started with the latest update (23.1.0).
The bug is not unique to a certain version of windows as the bug continued after updating to Windows 10 version 1809.
What is working:
-OBS captures the USB microphone audio fine and outputs to stream fine.
-Audio Monitoring works fine for desktop audio and media file sources.
-All other audio channels work fine (Mono, Stereo, 4.0, 4.1, 5.1, 7.1).
Problem:
-No Audio Monitoring for USB microphones only when the audio channel is set to 2.1 only.
Solution:
-Most likely a line of code is missing with the new audio meters for the 2.1 audio channel that links the audio meters to the audio monitor.
What is working:
Problem:
Solution:
