Nadeox1
Hello OBS Forum,
I was planning to use OBS for a quick projector work, and I have two question regarding the audio mixer:
1. Is there a way to set a default volume for sources? I'd like to avoid the audio source to play at maximum volume, resulting too loud. I rather have it start muted and raise it manually.
2. It's possible to default the Monitor setting to something else than off? Since it's a projector work, I want the audio come out from the PC output directly, but from what I've seen it defaults to off, meaning I have to change that manually for every source I have.
Bonus question:
3. There's no transition fading for audio sources? On my tests it cuts the audio of the sources directly.
Thank you in advance!
Bonus question:
