mavkeysound
It would be perfect if OBS showed the master level of the mix of all audio sources. And it would be much better if you could also insert plugins for the master output. For example, a vst plugin for audio normalization (the same audio plugins that can now be inserted in each source, but that can also be inserted in a master audio channel where the complete mix of the source audios is located.
That simply. Beforehand thank you very much.
