Audio issue with all the other kind on capture than desktop audio.
Virudi
Hello,
I am experiencing audio problems while capturing a game with Obs Studio. Crackles that appear and disappear randomly, at first I was using Streamlabs Desktop but I had the same problems and I migrated to OBS Studio thinking it would fix something.
Example 1: https://www.twitch.tv/virudi/clip/LightYummyBasenjiBuddhaBar-5Zz1msvRqFdyAkGg
Example 2: https://www.twitch.tv/virudi/clip/FunnyEnticingShallotDuDudu-rH6FMtlkVfDQTLVL
(It's in french, sorry about that)
At first I thought the hail was coming from the various plugins installed, so I reset everything without success. I was using OBS Beta application audio capture. I migrated to the Win Capture Audio plugin (https://github.com/bozbez/win-capture-audio/releases) but without success either. During the last stream, it was noticed that the crackling was not present when I use desktop audio capture.
Is there a solution to correct this audio crackling on the application capture?
There seems to be no actual fix, people are blaming the Windows audio system/drivers, but ALL my windows audio work fine, it's only OBS (Application Audio Beta) & the 3rd party plugin that's broken.
So I would suggest you stop using this broken feature, and use Steelseries GG for the Mixer (This is what I'm using, and it's great), it automatically separates game audio, it actually gives 5 different channels (Game, Chat, Media, Aux & Mic) which does not have this issue.
Hello,
