Audio issue (static?) when using Application Audio Capture (Beta)
There are times when I will randomly get a static sound (dont know a better way to describe it) when using application audio capture(beta) feature in obs. The static also only appears to affect one audio capture at a time. I thought it was tied to cpu/gpu usage but I have checked the logs and didn't find anything. I've tried many different things such as switching nvidia nvenc or x264. i've tried putting filters on my audio sources. I'll attach the logs and an example of the audio. I've made sure the sample rate in obs matches the same rate with my audio sources. 48kHz in obs and 8 channel, 16 bit, 48000Hz on headphones. 24 bit, 4800Hz (studio quality) with my speakers. Any help/ suggestions/ ideas would be appreciated! Thank you
Link to audio: https://imgur.com/a/8rlZKd8 (file was too large)
And I attached the log file from
  • 2024-09-21 20-04-23.txt
