Windows movies and TV. About saving to mp4, I do that to upload to youtube later. But what do you suggest?What program are you opening your recordings with?
Thanks, i'll try your both suggestions. VLC is capable to open MKV?Use VLC to open your recordings. And check your audio tracks individually.
And save to MKV. Youtube is fully capable of accepting MKVs. There are NO good reasons to save directly to mp4.
Thanks for all your tips. It worked perfectly!Yes. VLC has FAR greater format support than the windows built in software.
