20:30:09: Open Broadcaster Software v0.592b - 64bit ( ^ω^)
20:30:09: -------------------------------
20:30:09: CPU Name: Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz
20:30:09: CPU Speed: 3073MHz
20:30:09: Physical Memory: 6135MB Total, 2238MB Free
20:30:09: stepping id: 5, model 26, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 8, total cores 4
20:30:09: monitor 1: pos={0, 0}, size={1920, 1080}
20:30:09: Windows Version: 6.1 Build 7601 S
20:30:09: Aero is Disabled
20:30:09: OBS Modules:
20:30:09: Base Address Module
20:30:09: 000000003F850000 OBS.exe
20:30:09: 00000000E36A0000 OBSApi.dll
20:30:09: 00000000F4800000 DShowPlugin.dll
20:30:09: 00000000F4870000 GraphicsCapture.dll
20:30:09: 00000000F4BB0000 NoiseGate.dll
20:30:09: 00000000F4FB0000 PSVPlugin.dll
20:30:09: ------------------------------------------
20:30:09: Adapter 1
20:30:09: Video Adapter: NVIDIA GeForce GTX 660
20:30:09: Video Adapter Dedicated Video Memory: 2091319296
20:30:09: Video Adapter Shared System Memory: 2147479552
20:30:09: Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
20:30:09: Adapter 2
20:30:09: Video Adapter: NVIDIA GeForce GTS 250
20:30:09: Video Adapter Dedicated Video Memory: 1050345472
20:30:09: Video Adapter Shared System Memory: 2948132864
20:30:09: =====Stream Start: 2014-01-14, 20:30:09===============================================
20:30:09: Multithreaded optimizations: On
20:30:09: Base resolution: 960x540
20:30:09: Output resolution: 960x540
20:30:09: Loading up D3D10 on NVIDIA GeForce GTX 660 (Adapter 1)...
20:30:09: Audio Format: 48000hz
20:30:09: Playback device Default
20:30:09: Using desktop audio input: Line In (Scarlett 2i2 USB)
20:30:09: Using auxilary audio input: Line In (Scarlett 2i2 USB)
20:30:09: Audio Encoding: AAC
20:30:09: bitrate: 160
20:30:09: device: Logitech HD Pro Webcam C910,
20:30:09: device id \\?\usb#vid_046d&pid_0821&mi_02#6&314e4c29&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
20:30:09: chosen type: I420, usingFourCC: false, res: 864x480 - 864x480, frameIntervals: 333333-2000000
20:30:09: use buffering: false - 0, fourCC: 'I420'
20:30:09: audio device: Disable,
20:30:09: audio device id Disabled,
20:30:09:
20:30:10: Using directshow input
20:30:10: ------------------------------------------
20:30:10: device: Dxtory Video 1,
20:30:10: device id (null),
20:30:10: chosen type: RGB32, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-333333
20:30:10: use buffering: false - 0, fourCC: 00000000
20:30:10: audio device: Disable,
20:30:10: audio device id Disabled,
20:30:10:
20:30:10: Scene buffering time set to 400
20:30:10: Video Encoding: x264
20:30:10: fps: 30
20:30:10: width: 960, height: 540
20:30:10: preset: veryfast
20:30:10: profile: main
20:30:10: keyint: 60
20:30:10: CBR: yes
20:30:10: CFR: no
20:30:10: max bitrate: 500
20:30:10: buffer size: 500
20:30:10: MMDeviceAudioSource: Frequency for device 'Line In (Scarlett 2i2 USB)' is 352800, samples per sec is 44100
20:30:12: Using RTMP service: Twitch / Justin.tv
20:30:12: Server selection: rtmp://live-mia.justin.tv/app
20:30:12: Interface: Realtek RTL8169/8110 Family PCI Gigabit Ethernet NIC (NDIS 6.20) (ethernet, 1000 mbps)
20:30:13: Completed handshake with rtmp://live-mia.justin.tv/app in 574 ms.
20:30:14: SO_SNDBUF was at 8192
20:30:14: SO_SNDBUF is now 65536
20:30:20: Total frames encoded: 273, total frames duplicated: 0 (0.00%)
20:30:20: Total frames rendered: 274, number of late frames: 2 (0.73%) (it's okay for some frames to be late)
20:30:21: RTMPPublisher::SocketLoop: Graceful loop exit
20:30:21: Average send payload: 10050 bytes, average send interval: 112 ms
20:30:21: Number of times waited to send: 0, Waited for a total of 0 bytes
20:30:21: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
20:30:21: Number of bytes sent: 452268
20:30:21:
20:30:21: Profiler time results:
20:30:21:
20:30:21: ==============================================================
20:30:21: video thread frame - [100%] [avg time: 4.275 ms] [children: 67.7%] [unaccounted: 32.3%]
20:30:21: | scene->Preprocess - [63.9%] [avg time: 2.73 ms]
20:30:21: | GPU download and conversion - [3.84%] [avg time: 0.164 ms] [children: 3.13%] [unaccounted: 0.702%]
20:30:21: | | flush - [2.48%] [avg time: 0.106 ms]
20:30:21: | | CopyResource - [0.304%] [avg time: 0.013 ms]
20:30:21: | | conversion to 4:2:0 - [0.351%] [avg time: 0.015 ms]
20:30:21: Convert444Threads - [100%] [avg time: 0.365 ms] [children: 97.8%] [unaccounted: 2.19%]
20:30:21: | Convert444toNV12 - [97.8%] [avg time: 0.357 ms]
20:30:21: encoder thread frame - [100%] [avg time: 0.762 ms]
20:30:21:
20:30:21:
20:30:21: Profiler CPU results:
20:30:21:
20:30:21: video thread frame - [cpu time: avg 3.074 ms, total 842.405 ms] [avg calls per frame: 1]
20:30:21: | scene->Preprocess - [cpu time: avg 2.163 ms, total 592.803 ms] [avg calls per frame: 1]
20:30:21: | GPU download and conversion - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
20:30:21: | | flush - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
20:30:21: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
20:30:21: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
20:30:21: Convert444Threads - [cpu time: avg 0.416 ms, total 218.4 ms] [avg calls per frame: 2]
20:30:21: | Convert444toNV12 - [cpu time: avg 0.416 ms, total 218.4 ms] [avg calls per frame: 2]
20:30:21: encoder thread frame - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
20:30:21:
20:30:21: =====Stream End: 2014-01-14, 20:30:21=================================================
20:31:08: Settings::Video: Disabling Aero
20:31:09: =====Stream Start: 2014-01-14, 20:31:09===============================================
20:31:09: Multithreaded optimizations: On
20:31:09: Base resolution: 640x480
20:31:09: Output resolution: 640x480
20:31:09: ------------------------------------------
20:31:09: Loading up D3D10 on NVIDIA GeForce GTX 660 (Adapter 1)...
20:31:09: Audio Format: 48000hz
20:31:09: Playback device Default
20:31:09: Using desktop audio input: Line In (Scarlett 2i2 USB)
20:31:09: Using auxilary audio input: Line In (Scarlett 2i2 USB)
20:31:09: Audio Encoding: AAC
20:31:09: bitrate: 160
20:31:09: device: Logitech HD Pro Webcam C910,
20:31:09: device id \\?\usb#vid_046d&pid_0821&mi_02#6&314e4c29&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
20:31:09: chosen type: I420, usingFourCC: false, res: 640x480 - 640x480, frameIntervals: 166666-2000000
20:31:09: use buffering: false - 0, fourCC: 'I420'
20:31:09: audio device: Disable,
20:31:09: audio device id Disabled,
20:31:09:
20:31:09: Using directshow input
20:31:09: device: Dxtory Video 1,
20:31:09: device id (null),
20:31:09: chosen type: RGB32, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-333333
20:31:09: use buffering: false - 0, fourCC: 00000000
20:31:09:
20:31:09: Scene buffering time set to 400
20:31:09: Video Encoding: x264
20:31:09: fps: 30
20:31:09: width: 640, height: 480
20:31:09: preset: veryfast
20:31:09: profile: main
20:31:09: keyint: 60
20:31:09: CBR: yes
20:31:09: CFR: no
20:31:09: max bitrate: 500
20:31:09: buffer size: 500
20:31:09: MMDeviceAudioSource: Frequency for device 'Line In (Scarlett 2i2 USB)' is 352800, samples per sec is 44100
20:31:11: Using RTMP service: Twitch / Justin.tv
20:31:11: Server selection: rtmp://live-mia.justin.tv/app
20:31:11: Interface: Realtek RTL8169/8110 Family PCI Gigabit Ethernet NIC (NDIS 6.20) (ethernet, 1000 mbps)
20:31:12: Completed handshake with rtmp://live-mia.justin.tv/app in 1065 ms.
20:31:13: SO_SNDBUF was at 8192
20:31:13: SO_SNDBUF is now 65536
20:31:19: Total frames encoded: 288, total frames duplicated: 0 (0.00%)
20:31:19: Total frames rendered: 293, number of late frames: 1 (0.34%) (it's okay for some frames to be late)
20:31:20: RTMPPublisher::SocketLoop: Graceful loop exit
20:31:20: Average send payload: 2575 bytes, average send interval: 30 ms
20:31:20: Number of times waited to send: 0, Waited for a total of 0 bytes
20:31:20: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
20:31:20: Number of bytes sent: 399213
20:31:20:
20:31:20: Profiler time results:
20:31:20:
20:31:20: ==============================================================
20:31:20: video thread frame - [100%] [avg time: 3.729 ms] [children: 76.4%] [unaccounted: 23.6%]
20:31:20: | scene->Preprocess - [73.6%] [avg time: 2.745 ms]
20:31:20: | GPU download and conversion - [2.76%] [avg time: 0.103 ms] [children: 2.04%] [unaccounted: 0.724%]
20:31:20: | | flush - [1.69%] [avg time: 0.063 ms]
20:31:20: | | CopyResource - [0.295%] [avg time: 0.011 ms]
20:31:20: | | conversion to 4:2:0 - [0.0536%] [avg time: 0.002 ms]
20:31:20: Convert444Threads - [100%] [avg time: 0.228 ms] [children: 97.4%] [unaccounted: 2.63%]
20:31:20: | Convert444toNV12 - [97.4%] [avg time: 0.222 ms]
20:31:20: encoder thread frame - [100%] [avg time: 0.399 ms]
20:31:20:
20:31:20:
20:31:20: Profiler CPU results:
20:31:20:
20:31:20: video thread frame - [cpu time: avg 3.407 ms, total 998.406 ms] [avg calls per frame: 1]
20:31:20: | scene->Preprocess - [cpu time: avg 2.289 ms, total 670.805 ms] [avg calls per frame: 1]
20:31:20: | GPU download and conversion - [cpu time: avg 0.159 ms, total 46.8 ms] [avg calls per frame: 1]
20:31:20: | | flush - [cpu time: avg 0.053 ms, total 15.6 ms] [avg calls per frame: 1]
20:31:20: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
20:31:20: | | conversion to 4:2:0 - [cpu time: avg 0.056 ms, total 15.6 ms] [avg calls per frame: 1]
20:31:20: Convert444Threads - [cpu time: avg 0.056 ms, total 31.2 ms] [avg calls per frame: 2]
20:31:20: | Convert444toNV12 - [cpu time: avg 0.056 ms, total 31.2 ms] [avg calls per frame: 2]
20:31:20: encoder thread frame - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
20:31:20:
20:31:20: =====Stream End: 2014-01-14, 20:31:20=================================================
20:31:35: Settings::Video: Disabling Aero
20:31:36: =====Stream Start: 2014-01-14, 20:31:36===============================================
20:31:36: Multithreaded optimizations: On
20:31:36: Base resolution: 1920x1080
20:31:36: Output resolution: 852x480
20:31:36: ------------------------------------------
20:31:36: Loading up D3D10 on NVIDIA GeForce GTX 660 (Adapter 1)...
20:31:36: Audio Format: 48000hz
20:31:36: Playback device Default
20:31:36: Using desktop audio input: Line In (Scarlett 2i2 USB)
20:31:36: Using auxilary audio input: Line In (Scarlett 2i2 USB)
20:31:36: Audio Encoding: AAC
20:31:36: bitrate: 160
20:31:36: device: Logitech HD Pro Webcam C910,
20:31:36: device id \\?\usb#vid_046d&pid_0821&mi_02#6&314e4c29&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
20:31:36: chosen type: I420, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-2000000
20:31:36: use buffering: false - 0, fourCC: 'I420'
20:31:36: audio device: Disable,
20:31:36: audio device id Disabled,
20:31:36:
20:31:37: Using directshow input
20:31:37: ------------------------------------------
20:31:37: device: Dxtory Video 1,
20:31:37: device id (null),
20:31:37: chosen type: RGB32, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-333333
20:31:37: use buffering: false - 0, fourCC: 00000000
20:31:37: audio device: Disable,
20:31:37: audio device id Disabled,
20:31:37:
20:31:37: Scene buffering time set to 400
20:31:37: Video Encoding: x264
20:31:37: fps: 30
20:31:37: width: 852, height: 480
20:31:37: preset: veryfast
20:31:37: profile: main
20:31:37: keyint: 60
20:31:37: CBR: yes
20:31:37: CFR: no
20:31:37: max bitrate: 500
20:31:37: buffer size: 500
20:31:37: MMDeviceAudioSource: Frequency for device 'Line In (Scarlett 2i2 USB)' is 352800, samples per sec is 44100
20:31:39: Using RTMP service: Twitch / Justin.tv
20:31:39: Server selection: rtmp://live-mia.justin.tv/app
20:31:39: Interface: Realtek RTL8169/8110 Family PCI Gigabit Ethernet NIC (NDIS 6.20) (ethernet, 1000 mbps)
20:31:39: Completed handshake with rtmp://live-mia.justin.tv/app in 612 ms.
20:31:41: SO_SNDBUF was at 8192
20:31:41: SO_SNDBUF is now 65536
20:31:48: RTMPPublisher::SocketLoop: Stalled for 2086 ms to write 129798 bytes (buffer: 0 / 131072), unstable connection?
20:32:52: RTMPPublisher::SocketLoop: Stalled for 1566 ms to write 94472 bytes (buffer: 0 / 131072), unstable connection?
20:32:58: RTMPPublisher::SocketLoop: Stalled for 1920 ms to write 127065 bytes (buffer: 0 / 131072), unstable connection?
20:33:00: RTMPPublisher::SocketLoop: Stalled for 1865 ms to write 130933 bytes (buffer: 0 / 131072), unstable connection?
20:33:04: RTMPPublisher::SocketLoop: Stalled for 1501 ms to write 124997 bytes (buffer: 0 / 131072), unstable connection?
20:33:07: RTMPPublisher::SocketLoop: Stalled for 1710 ms to write 125411 bytes (buffer: 0 / 131072), unstable connection?
20:33:11: RTMPPublisher::SocketLoop: Stalled for 2843 ms to write 127844 bytes (buffer: 0 / 131072), unstable connection?
20:33:34: RTMPPublisher::SocketLoop: Stalled for 1844 ms to write 118512 bytes (buffer: 0 / 131072), unstable connection?
20:33:55: RTMPPublisher::SocketLoop: Stalled for 1699 ms to write 130886 bytes (buffer: 0 / 131072), unstable connection?
20:34:06: RTMPPublisher::SocketLoop: Stalled for 1680 ms to write 130610 bytes (buffer: 0 / 131072), unstable connection?
20:34:10: RTMPPublisher::SocketLoop: Stalled for 1642 ms to write 129128 bytes (buffer: 0 / 131072), unstable connection?
20:34:12: RTMPPublisher::SocketLoop: Stalled for 1929 ms to write 130923 bytes (buffer: 0 / 131072), unstable connection?
20:34:15: RTMPPublisher::SocketLoop: Stalled for 3671 ms to write 130932 bytes (buffer: 0 / 131072), unstable connection?
20:34:17: RTMPPublisher::SocketLoop: Stalled for 2164 ms to write 130857 bytes (buffer: 0 / 131072), unstable connection?
20:34:21: RTMPPublisher::SocketLoop: Stalled for 3379 ms to write 127665 bytes (buffer: 0 / 131072), unstable connection?
20:34:22: RTMPPublisher::SocketLoop: Stalled for 1614 ms to write 127287 bytes (buffer: 0 / 131072), unstable connection?
20:34:24: RTMPPublisher::SocketLoop: Stalled for 2002 ms to write 129226 bytes (buffer: 0 / 131072), unstable connection?
20:34:29: RTMPPublisher::SocketLoop: Stalled for 1814 ms to write 130173 bytes (buffer: 0 / 131072), unstable connection?
20:34:32: RTMPPublisher::SocketLoop: Stalled for 3544 ms to write 129705 bytes (buffer: 0 / 131072), unstable connection?
20:34:35: RTMPPublisher::SocketLoop: Stalled for 2571 ms to write 130303 bytes (buffer: 0 / 131072), unstable connection?
20:34:38: RTMPPublisher::SocketLoop: Stalled for 1613 ms to write 129276 bytes (buffer: 0 / 131072), unstable connection?
20:34:42: RTMPPublisher::SocketLoop: Stalled for 1564 ms to write 126133 bytes (buffer: 0 / 131072), unstable connection?
20:34:48: RTMPPublisher::SocketLoop: Stalled for 1620 ms to write 128334 bytes (buffer: 0 / 131072), unstable connection?
20:34:50: RTMPPublisher::SocketLoop: Stalled for 2002 ms to write 130547 bytes (buffer: 0 / 131072), unstable connection?
20:34:53: RTMPPublisher::SocketLoop: Stalled for 2275 ms to write 129101 bytes (buffer: 0 / 131072), unstable connection?
20:34:56: RTMPPublisher::SocketLoop: Stalled for 1649 ms to write 127414 bytes (buffer: 0 / 131072), unstable connection?
20:34:59: RTMPPublisher::SocketLoop: Stalled for 1798 ms to write 130594 bytes (buffer: 0 / 131072), unstable connection?
20:35:02: RTMPPublisher::SocketLoop: Stalled for 1841 ms to write 127846 bytes (buffer: 0 / 131072), unstable connection?
20:35:05: RTMPPublisher::SocketLoop: Stalled for 1627 ms to write 127898 bytes (buffer: 0 / 131072), unstable connection?
20:35:08: RTMPPublisher::SocketLoop: Stalled for 3329 ms to write 130948 bytes (buffer: 0 / 131072), unstable connection?
20:35:11: RTMPPublisher::SocketLoop: Stalled for 1714 ms to write 129404 bytes (buffer: 0 / 131072), unstable connection?
20:35:17: RTMPPublisher::SocketLoop: Stalled for 3470 ms to write 130663 bytes (buffer: 0 / 131072), unstable connection?
20:35:20: RTMPPublisher::SocketLoop: Stalled for 3121 ms to write 130943 bytes (buffer: 0 / 131072), unstable connection?
20:35:23: RTMPPublisher::SocketLoop: Stalled for 2637 ms to write 130528 bytes (buffer: 0 / 131072), unstable connection?
20:35:25: RTMPPublisher::SocketLoop: Stalled for 1965 ms to write 130793 bytes (buffer: 0 / 131072), unstable connection?
20:35:29: RTMPPublisher::SocketLoop: Stalled for 1564 ms to write 103360 bytes (buffer: 0 / 131072), unstable connection?
20:35:30: RTMPPublisher::SocketLoop: Stalled for 1574 ms to write 130915 bytes (buffer: 0 / 131072), unstable connection?
20:35:33: RTMPPublisher::SocketLoop: Stalled for 1754 ms to write 129245 bytes (buffer: 0 / 131072), unstable connection?
20:35:35: RTMPPublisher::SocketLoop: Stalled for 1796 ms to write 130848 bytes (buffer: 0 / 131072), unstable connection?
20:35:38: RTMPPublisher::SocketLoop: Stalled for 2731 ms to write 128447 bytes (buffer: 0 / 131072), unstable connection?
20:35:41: RTMPPublisher::SocketLoop: Stalled for 1680 ms to write 130816 bytes (buffer: 0 / 131072), unstable connection?
20:35:43: RTMPPublisher::SocketLoop: Stalled for 2242 ms to write 130915 bytes (buffer: 0 / 131072), unstable connection?
20:35:45: RTMPPublisher::SocketLoop: Stalled for 1873 ms to write 128748 bytes (buffer: 0 / 131072), unstable connection?
20:35:47: RTMPPublisher::SocketLoop: Stalled for 1701 ms to write 130215 bytes (buffer: 0 / 131072), unstable connection?
20:35:49: RTMPPublisher::SocketLoop: Stalled for 2743 ms to write 128266 bytes (buffer: 0 / 131072), unstable connection?
20:35:52: RTMPPublisher::SocketLoop: Stalled for 2079 ms to write 129250 bytes (buffer: 0 / 131072), unstable connection?
20:35:53: RTMPPublisher::SocketLoop: Stalled for 1501 ms to write 130987 bytes (buffer: 0 / 131072), unstable connection?
20:35:56: RTMPPublisher::SocketLoop: Stalled for 1865 ms to write 130956 bytes (buffer: 0 / 131072), unstable connection?
20:35:58: RTMPPublisher::SocketLoop: Stalled for 1594 ms to write 130728 bytes (buffer: 0 / 131072), unstable connection?
20:36:01: RTMPPublisher::SocketLoop: Stalled for 2781 ms to write 130937 bytes (buffer: 0 / 131072), unstable connection?
20:36:02: RTMPPublisher::SocketLoop: Stalled for 1536 ms to write 131001 bytes (buffer: 0 / 131072), unstable connection?
20:36:09: RTMPPublisher::SocketLoop: Stalled for 2022 ms to write 130627 bytes (buffer: 0 / 131072), unstable connection?
20:36:12: RTMPPublisher::SocketLoop: Stalled for 2296 ms to write 128515 bytes (buffer: 0 / 131072), unstable connection?
20:36:14: RTMPPublisher::SocketLoop: Stalled for 1956 ms to write 128939 bytes (buffer: 0 / 131072), unstable connection?
20:36:17: RTMPPublisher::SocketLoop: Stalled for 2903 ms to write 130763 bytes (buffer: 0 / 131072), unstable connection?
20:36:19: RTMPPublisher::SocketLoop: Stalled for 2313 ms to write 130617 bytes (buffer: 0 / 131072), unstable connection?
20:36:21: RTMPPublisher::SocketLoop: Stalled for 1956 ms to write 130703 bytes (buffer: 0 / 131072), unstable connection?
20:36:23: RTMPPublisher::SocketLoop: Stalled for 1806 ms to write 117948 bytes (buffer: 0 / 131072), unstable connection?
20:36:47: RTMPPublisher::SocketLoop: Stalled for 1940 ms to write 107422 bytes (buffer: 0 / 131072), unstable connection?
20:36:48: RTMPPublisher::SocketLoop: Stalled for 1506 ms to write 103644 bytes (buffer: 0 / 131072), unstable connection?
20:36:50: RTMPPublisher::SocketLoop: Stalled for 1568 ms to write 89839 bytes (buffer: 0 / 131072), unstable connection?
20:36:52: RTMPPublisher::SocketLoop: Stalled for 2376 ms to write 128568 bytes (buffer: 0 / 131072), unstable connection?
20:36:56: RTMPPublisher::SocketLoop: Stalled for 2308 ms to write 129973 bytes (buffer: 0 / 131072), unstable connection?
20:36:59: RTMPPublisher::SocketLoop: Stalled for 2805 ms to write 130184 bytes (buffer: 0 / 131072), unstable connection?
20:37:03: RTMPPublisher::SocketLoop: Stalled for 3954 ms to write 129999 bytes (buffer: 0 / 131072), unstable connection?
20:37:04: RTMPPublisher::SocketLoop: Stalled for 1548 ms to write 91383 bytes (buffer: 0 / 131072), unstable connection?
20:37:06: RTMPPublisher::SocketLoop: Stalled for 1546 ms to write 71380 bytes (buffer: 0 / 131072), unstable connection?
20:37:10: RTMPPublisher::SocketLoop: Stalled for 1596 ms to write 83061 bytes (buffer: 0 / 131072), unstable connection?
20:37:12: RTMPPublisher::SocketLoop: Stalled for 1867 ms to write 129651 bytes (buffer: 0 / 131072), unstable connection?
20:37:15: RTMPPublisher::SocketLoop: Stalled for 2218 ms to write 125902 bytes (buffer: 0 / 131072), unstable connection?
20:38:35: RTMPPublisher::SocketLoop: Stalled for 2180 ms to write 129985 bytes (buffer: 0 / 131072), unstable connection?
20:38:38: RTMPPublisher::SocketLoop: Stalled for 1615 ms to write 110978 bytes (buffer: 0 / 131072), unstable connection?
20:38:44: RTMPPublisher::SocketLoop: Stalled for 1754 ms to write 105051 bytes (buffer: 0 / 131072), unstable connection?
20:38:47: RTMPPublisher::SocketLoop: Stalled for 3132 ms to write 128559 bytes (buffer: 0 / 131072), unstable connection?
20:38:52: RTMPPublisher::SocketLoop: Stalled for 4533 ms to write 128044 bytes (buffer: 0 / 131072), unstable connection?
20:38:54: RTMPPublisher::SocketLoop: Stalled for 1857 ms to write 111295 bytes (buffer: 0 / 131072), unstable connection?
20:39:18: RTMPPublisher::SocketLoop: Stalled for 2575 ms to write 127836 bytes (buffer: 0 / 131072), unstable connection?
20:39:21: RTMPPublisher::SocketLoop: Stalled for 2645 ms to write 129126 bytes (buffer: 0 / 131072), unstable connection?
20:39:24: RTMPPublisher::SocketLoop: Stalled for 1572 ms to write 103951 bytes (buffer: 0 / 131072), unstable connection?
20:39:27: RTMPPublisher::SocketLoop: Stalled for 3135 ms to write 130831 bytes (buffer: 0 / 131072), unstable connection?
20:39:29: RTMPPublisher::SocketLoop: Stalled for 1933 ms to write 74268 bytes (buffer: 0 / 131072), unstable connection?
20:39:31: RTMPPublisher::SocketLoop: Stalled for 1791 ms to write 112132 bytes (buffer: 0 / 131072), unstable connection?
20:39:36: RTMPPublisher::SocketLoop: Stalled for 3010 ms to write 128781 bytes (buffer: 0 / 131072), unstable connection?
20:40:59: RTMPPublisher::SocketLoop: Stalled for 1675 ms to write 76936 bytes (buffer: 0 / 131072), unstable connection?
20:42:49: RTMPPublisher::SocketLoop: Stalled for 2934 ms to write 129960 bytes (buffer: 0 / 131072), unstable connection?
20:42:52: RTMPPublisher::SocketLoop: Stalled for 2151 ms to write 128124 bytes (buffer: 0 / 131072), unstable connection?
20:42:56: RTMPPublisher::SocketLoop: Stalled for 1601 ms to write 114059 bytes (buffer: 0 / 131072), unstable connection?
20:42:59: RTMPPublisher::SocketLoop: Stalled for 2430 ms to write 128342 bytes (buffer: 0 / 131072), unstable connection?
20:43:01: RTMPPublisher::SocketLoop: Stalled for 1576 ms to write 104156 bytes (buffer: 0 / 131072), unstable connection?
20:43:15: RTMPPublisher::SocketLoop: Stalled for 1506 ms to write 79490 bytes (buffer: 0 / 131072), unstable connection?
20:43:18: RTMPPublisher::SocketLoop: Stalled for 2115 ms to write 130508 bytes (buffer: 0 / 131072), unstable connection?
20:43:24: Total frames encoded: 21193, total frames duplicated: 171 (0.81%)
20:43:24: Total frames rendered: 21154, number of late frames: 9 (0.04%) (it's okay for some frames to be late)
20:43:25: RTMPPublisher::SocketLoop: Aborting due to WSAEnumNetworkEvents failure, 10038
20:43:25: Average send payload: 9382 bytes, average send interval: 138 ms
20:43:25: Number of times waited to send: 106, Waited for a total of 260271 bytes
20:43:25: Number of b-frames dropped: 795 (3.8%), Number of p-frames dropped: 956 (4.5%), Total 1751 (8.3%)
20:43:25: Number of bytes sent: 47588398
20:43:25:
20:43:25: Profiler time results:
20:43:25:
20:43:25: ==============================================================
20:43:25: video thread frame - [100%] [avg time: 4.917 ms] [children: 83.9%] [unaccounted: 16.1%]
20:43:25: | scene->Preprocess - [78.7%] [avg time: 3.872 ms]
20:43:25: | GPU download and conversion - [5.15%] [avg time: 0.253 ms] [children: 3.07%] [unaccounted: 2.07%]
20:43:25: | | flush - [2.12%] [avg time: 0.104 ms]
20:43:25: | | CopyResource - [0.915%] [avg time: 0.045 ms]
20:43:25: | | conversion to 4:2:0 - [0.0407%] [avg time: 0.002 ms]
20:43:25: Convert444Threads - [100%] [avg time: 0.32 ms] [children: 99.1%] [unaccounted: 0.938%]
20:43:25: | Convert444toNV12 - [99.1%] [avg time: 0.317 ms]
20:43:25: encoder thread frame - [100%] [avg time: 0.633 ms]
20:43:25:
20:43:25:
20:43:25: Profiler CPU results:
20:43:25:
20:43:25: video thread frame - [cpu time: avg 3.887 ms, total 82243.7 ms] [avg calls per frame: 1]
20:43:25: | scene->Preprocess - [cpu time: avg 3.377 ms, total 71448.5 ms] [avg calls per frame: 1]
20:43:25: | GPU download and conversion - [cpu time: avg 0.066 ms, total 1404.01 ms] [avg calls per frame: 1]
20:43:25: | | flush - [cpu time: avg 0.028 ms, total 592.809 ms] [avg calls per frame: 1]
20:43:25: | | CopyResource - [cpu time: avg 0.012 ms, total 265.202 ms] [avg calls per frame: 1]
20:43:25: | | conversion to 4:2:0 - [cpu time: avg 0.002 ms, total 62.4 ms] [avg calls per frame: 1]
20:43:25: Convert444Threads - [cpu time: avg 0.328 ms, total 13899.7 ms] [avg calls per frame: 2]
20:43:25: | Convert444toNV12 - [cpu time: avg 0.325 ms, total 13743.7 ms] [avg calls per frame: 2]
20:43:25: encoder thread frame - [cpu time: avg 0.106 ms, total 2262.02 ms] [avg calls per frame: 1]
20:43:25:
20:43:25: =====Stream End: 2014-01-14, 20:43:25=================================================
