Audio Freezing/Pausing/Breaking Followed By Audio Delay
BlueNine
I just recently started recording from my Switch using a Mirabox (it's called a "Treaslin" but the device is recognized as "Mirabox" by my PC). Recently, I had an incident where I was going over a recording and the audio just breaks for a solid few seconds, then comes back delayed by at least 12 seconds. I recorded a second video right after that one that had similar audio delay. I decided to go back through my recordings and have found a few occasions where the audio just stops for some reason and then comes back, remaining delayed for the remainder of the recording. Is there anyway to fix this in OBS or is this a problem with the capture card device?
I think this is the right log file. This is the one where the audio outright broke.
I found a work around. I think it was the capture card. I had Windows listen to the capture card and recorded via desktop audio without any issues so far. As long as I don't accidentally mute OBS.
Below is the problem I was having, time stamp 11:44. (Spoilers for Pokémon Legends: Arceus).
Other cases were only about one or two seconds long.
