Question / Help Audio echo on stream from members of a skype call
lunchbox739
I have been attempting to stream a multi person skype call to twitch using OBS and have been getting an audio echo on every other person on the group call other than myself on the stream. After some digging around online I have discovered this is an issue many have encountered before me and after toying around with settings per the many suggestions I've read about in other threads, I still have yet to remedy the problem. All parties on call are on headsets, twitch isn't being monitored on unmuted separate devices so obviously I have audio being fed to multiple channels creating the echo I just cant seem to figure out from where.
What I'd like to accomplish: The stream setup is fairly simple, 3 scenes total. Scene 1 is a "stream will begin shortly" graphic with looped audio. Scene 2 is the "chat" scene where I have separate windows for each skype caller arranged on a image background for better aesthetics than a screen cast skype call . This is of course where the bulk of the stream time is spent discussing the topic of the livestream. scene 3 is a "thank you for watching" graphic with looped audio. this configuration allows us to start the stream on scene 1 to begin recording, switch to scene 2 for the stream content and end on scene 3 where the recording is ended.
What I am using: My PC is higher end gaming machine with no capture card, I am using a wireless gaming headset with mic. The call is conducted on the latest version of skype and the content is broadcast to twitch via OBS. No other software is utilized
How would those of you far more experienced with this medium go about setting this up to function on stream as described above with clean audio?
many thanks in advance to those of you whom take the time to assist.
ok so as it seems there is no solution or configuration that actually corrects this problem for mor ethan one guest skype user.....what would folks here suggest software wise to use to be able to accomplish the above goal?
